Question about Sangean Audio Players & Recorders
Backlight will not stay on
Backlight on SangeanK-200 turns itself off a few seconds after it is set
Demmy
  • 59 Answers
SOURCE: Backlight of LCD turns off
For latitude systems they have this ambient light sensor. it basically adjusts the brightness of the screen depening on room lighting. try to go to bios by hitting F2 on the dell logo. go to video and try to look for ambient light sensor. however, im not sure if your computer has that feature I have a second option for you though. based on the troubleshooting you've done, it seems that the video back lighting is affected by movement. it would be a good try to reseat the LCD cable. you can use this link to guide you in fixing the computer : http://support.dell.com/support/edocs/systems/latd505/sm/keyboard.htm
all you need to do is to take out the keyboard with 2 screw holding it in place. the LCD cable should then be accessible. it a thick cable that coming out of the Left hinge.
Hope this helps.
thanks.
Posted on Dec 25, 2007
  • 20 Answers
SOURCE: the backlight on my laptop is not staying on
There is settings for your screen in the display options. Sounds like you need to fix a couple settings.
Posted on Oct 19, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Backlight wont stay on
The inverter board which provides the backlight power isn't working properly. This is a pretty common problem with LCD screens. The inverter is in the display, mounted under the display panel. It's a fairly simple job to replace the inverter. You have to remove the screws holding the front of the display to the back and separate the pieces. The inverter is held in place by a couple of screws and has a couple of cables connecting it to the main board and display panel. Unplug those, remove the inverter, mount the replacement and plug the cables back in. Then reassemble the display. A search on Google for "acer 5315 inverter" turned up several sources for the replacement part. Here is one. I don't know anything about this seller; I just picked it as an example.
Posted on May 19, 2009
Hitachi-mex
  • 26 Answers
SOURCE: Receiver turns for a fews seconds then shuts down
Hi.
If the word "OVERLOAD" is in your display, we have a bad channel.
But if only turn off, and the standby led is on all the time, you need change a couple of resistor of 10 Ohms at 2 Watts in main board. But you need disassamble a must all the amplifier. A lot of work, but cheap part.
Best regards.
Posted on Oct 23, 2009
bobaloub
  • 6 Answers
SOURCE: TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Posted on Mar 10, 2010
I thought I asked this already but it does not show up. I have a 15" lcd tv that will only stay lighted for a few seconds on each channel then goes dark. I can kinda see a image on the dark screen. I...
the backlight is either going out or the capacitor for the backlight is bad to where its not storing enough power to run the backlight the start capacitor must be good but the run capacitor might be bad usually the backlight itself goes bad but not if it turns on for a few seconds it would have to be the capacitor.
Oct 04, 2013 | Philips Magnavox 15MF400T 15 in. LCD...
V7 S20PD monitor goes blank after 1 second!
This is usually caused by one of the inverter transformers that drive the backlights, or the backlight itself. The capacitors should not be ruled out, to fix it will be expensive venture.
May 16, 2012 | V7 Computers & Internet
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
Dec 11, 2010 | LG 42LG30 42 in. LCD HDTV
Sony kdl-40s2000 won't stay on and blink red 4 times
That error says backlight failure. It has to be troubleshooted to find out why.
Apr 20, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
CVizio 32" background lamp won't stay on
Ur backlight inverter ic board is dead must be replace.
Aug 31, 2009 | Vizio L32 32 in. LCD HDTV
May 19, 2009 | Acer Aspire 5315 Notebook
Tocco backlight not staying on.
Menu > settings > display and light settings > light settings > backlight time > dim> change time till dim upto 3 mins. back >on >change time light stays on .
Jan 18, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
The backlight on my laptop is not staying on
Oct 17, 2008 | Acer Aspire 5610-4648 Notebook
47 people viewed this question
Top Sangean Audio Players & Recorders Experts
Mark Schmit
Mark Schmit
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
