Question about Fitbit Weight Tracker
I can't get my fit bit force to charge.
I plug it in to charge and it's not charging.
Dropped my new zte n9130 boost mobile phone when it was just about dead . Went to charge it and no light no charge and not turning on?? Is this product a good one?
You may have knocked loose the little "plug" that your charger fits into to charge it. It is soldered onto the board inside and, and if it is no longer attached it won't charge anymore.
See if the plug jiggles a bit if you play with it when a cord is plugged in. If it moves that is a problem and means that you need a repair. Even if it doesn't move, it may just be packed in there tight but is still broken.
Sep 10, 2015 | ZTE Cell Phones
My ipod wont charge
It might have a dead battery.First ,if the battery is really dead it will take a long while before it will charge (more than normal). But, I will give you a house hold remedies and hopefully it will work. Plug it in to charge normally and the flat end of the cable that goes connected to ipod you want to pull upward towards the side of the screen. You will be applying a bit of force ( not too much that you would break it) and hold it for maybe 10 seconds. Give it a bit and you should see it charge.
Jul 02, 2014 | Audio Players & Recorders
My jabra BT160 won't charge
i had the same problem with mine. the problem is with the completely empty battery.
solution is to disassemble it and force charge the battery inside.
you have to cut any usb cable leaving the side which connects to pc and remove the insolation from red and black wires. connect them for few seconds to battery soldering points on jabra board (red to red, black to black, sometimes you have to scratch the solder a bit if it oxidized a bit). once you see the light you can start charging it normally.
Sep 23, 2009 | Jabra BT160 Wireless Headset
Phone not switching on
where you plug the charger in on your phone, if you look into it you will be able to see the contacts for it to charge.
on the inner OUTER wall of it ther is 2 pins, use a needle to pull them out a little bit but be carefull not to sanp them.
just so they stick out a little bit, if you do this and the charger dont go in then dont bloody force it in otherwise ya buggered.lol
only when the orange light is on its charging, if you accour a flashing orange light do it again.
this should sort your charge problem.
however you will eventuall need to do it again.
Aug 20, 2009 | HTC P3300 Smartphone
Why won't my computer charge
the battery might be going bad on it, try taking the battery out and running the computer just off of the plug. that series of HP has overheating issues and are prone to randomly shutting down. if you have a bad battery, it can overstress the powersupply trying to charge a bad battery. Also, the solder joints tend to go bad on the motherboard where the power jack is connected to it, so try holding your power wire at a bit of an angle while turning it on and see if that does the trick (the sideways force can temporarily connect those broken joints.. There was also a class action settlement on these computers i believe, so google class action zd7000 and see if you qualify. The power plug jack was part of this, so you might get it fixed free of charge.
Jul 08, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
LG Venus Charging Problems
try borrowing another charger that fits your phone, If it works change the charger as the cord might be broken//
Oct 03, 2017 | LG Venus VX8800 Cellular Phone
Fitbit Weight Tracker Logo
51 people viewed this question
Top Fitbit Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Fitbit Facebook App Expert? Answer questions, earn points and help others
