Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Its only half a vscreen
Half a screeen
Has a blue vertical line on middel of the screen.
please contact ur vendor it will cost u less then $3 to get it repaired
Apr 01, 2014 | Panasonic BT-LH1700W Monitor
Sanyo half screeen
Top/bottom or left right ? a model number might help here.
Aug 28, 2012 | Sanyo Televison & Video
I have a tz61v61 toshiba rear projection. The bottom half of the screeen is ghosting red, blue and green. it looks like 3d without the glasses. top half of screen is fine.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Toshiba TZ61V61 61" Rear Projection...
I have a samsung crt 15'' monitor display is coming on the half of the screen
Dear User,
You can adjust the Display from the Front Pannel Controls on the Monitor.
Use these buttons to make the display to come up with full screen on the monitor
You can also sort such problem by setting the screeen resolution in Display Properties in Windows upto some extent.
Thanks
Jan 24, 2010 | Computers & Internet
Screeen flickers
water damage, dropped it too many times, faulty hardware. probably water damage though, thats what happened to mine.
Jul 13, 2009 | Nintendo DS Lite Console
My letters on the screeen ar blurry look like a bad copy and I can't read anything-also , everything on the screen kind of shifted to the left so I can't see my back button for example or like half of my...
Is you monitor an LCD?
Did you change the resolution you are running at? LCD's dont really like being run at anything but there native resolution.
If not, try the OSD settings. The monitor most likely has buttons on the front of sides to control them. Dont worry, ther isnt anything in there that can cause harm to your screen.
Dec 01, 2008 | Computers & Internet
Screeen
Check local repair depots in your area for a quote to repair it.......or if you have insurance, see if the damage is covered.
Nov 06, 2008 | Vizio GV42L 42 in. LCD Television
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
