Basket does not spin. It blew the circuit breaker, when I reset it I heard arcing, now no arcing will fill but not spin, motor does not smell burnt
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
I have a maytag model# mav2755aww, I have a burn smell when it's in the spin cycle. yes it is spinning the water is draining ?
Burning odor may be coming from a overheated motor under a heavy spin load.
Before going any further;
1.Make sure the circuit breaker for the machine is working properly and know its location.
2.Have a working fire extinguisher nearby.
3.If a electrical/motor fire starts, you need to turn off breaker power to the washer..Then use the extinguisher to put out any fire.
Try spinning the basket empty and see if the odor still persists if so, you need a new motor ..
If not, you have to think about the weight of the washload that the spin cycle must handle..
If a light load causes the same odor, stop using the machine until you replace the motor and check the transmission for any problems.
Oct 02, 2014 | Washing Machines
Washer will fill with water and then pops the circuit breaker
see the causes:
t doesn't pump or spin
frozen puller+ belt broken replace
It pumps, but doesn't spin
lid swithc broker or open,motor coupler broken,belt broken, and clutch worn,drive motor defective,transmision not shifting properly,basket driven worn.
It spins only with the lid closed lid switch prevent the action to start.
see the diagram
Jun 19, 2012 | Washing Machines
How do u reset a cutler hammer arc fault breaker if nothing happens after u press the reset switch and flip the breaker on
if the breaker wont resest it seems you had to many amps running through and it blew out,Or there is a loose wire that is setting the breaker off go through where it is hooked up and make sure all the wires are tight, if they are your cuttler just blew out,good luck
Aug 06, 2011 | Electrical Supplies
Model number WDSR2080G3WW. GE Top Loading Washing machine will not spin. It fills, agitates and drains but does not spin. Lid switch engages, motor tries to start the spin it won't spin, so the motor...
The reason for the hot smell must be investigated. If it is the motor that is getting hot it won't be a new motor for very long. The hot smell might be coming from a drive belt or a clutch and there could be a brake mechanism that is binding or not fully releasing.
Clearly the next step is to closely observe the operation of the mechanical parts...
Sep 15, 2017 | Washing Machines
Heard a loud pop...saw a bright flash...burnt smelled and dryer stopped working. Circuit breaker will not re-set.
You may have a wire that has come loose of it's restraints and is rubbing on the drum as it turns. This would cause the wire's insulation to wear off, and if it's an electric dryer, you're dealing with 220volt wiring. The spark and burning smell is similar to arc welding.
You'll need to open the dryer up and find the damaged wire and reinsulate it with electrical tape or heat-shrink wrap.
It should be easily visible ...look for the burnt,blackened marks..
Nov 01, 2009 | Frigidaire Dryers
Washer stopped working all together
Hi,Check your water solenoid valve, the part where you connect (2) hoses, could be burnt out, sometimes they do, especially if your water pressure home (building) is low, or could be your motor, remove back of machine and check water valve, check valve with ohm tester, or visual check can tell you, if burnt out, replace it, few things could burnt out, motor, capacitor, switches/relay etc, but first check water intake (solenoid) valve, also,check / reset, fuse/circuit breaker, probably went of, when burning smell occurs, ( happened) if it's not your water intake valve, let me know, we can check other possibilities. but i believe it's your valve, good luck.
Aug 13, 2009 | Magic Chef CAV4000AWW Top Load Washer
Air conditioner pop and then blew refriderant or something
Inspect the capacitor for failure. if it is not swollen or leaky then the compressor might be gone.264f733.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 08, 2009 | Kenmore Room Air Conditioner
NO Agitator, draining or spin
Since the breaker did not trip i am going to assume that the washer stopped because the motor overload switch tripped or contacts burnt. Was there any smell of any burning (electrical burning)?. It could have stopped because a contact on the timer got burnt too. Have a look also at the water level swirch
Regards
Oct 04, 2008 | Whirlpool LSB6200KQ Top Load Washer
Maytag Neptune front load washer (top of the line)
some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Oct 26, 2006 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
