Question about Frigidaire Affinity ATF6000F Front Load Washer
How can i tell if pump is bad
Ltf2140fs2 washer have drain pump out how do i tell if pump is buying a new one
How do i get rid of the e-13 error on my Bosch Washer?
Yep, Bosch are bad and common to fault at a very young age, ECU in these machines are far from satisfactory and would steer clear of Bosch at all costs
Nov 21, 2014 | Bosch Washing Machines
Error code on ltf2140fs2
Hello friend, I appreciate your post!
From my understanding your front load washer LTF2140FS2 is beeping 9 times and then you have to unplug it and plug it back in. When the unit is beeping do you notice any additional lights on the panel coming on? This information would be helpful in assisting you with getting a proper explanation to your current problem. -Matt
Jul 19, 2014 | Frigidaire Washing Machines
I have an oil leak from a drain hole in front of engine.what could be the problem?
If the oil plug bolt is leaking you need a new aluminum sealing washer. There are no oil weep holes in the front of the motor. Is it the weep hole under the water pump? You probably have a bad water pump seal or a bad oil seal on the water pump shaft. Buy a new water pump and the K&L water pump gasket kit. The K&L gasket kit comes with all the gaskets, seals, and washers necessary to do the water pump replacement for a fraction of the cost of the OEM Honda individual gaskets, seals, and washers.
Jan 30, 2011 | 1985 Honda GL 1200 Aspencade Gold Wing
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
POSSIBLE CAUSES:
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Electrical line connected to the drain pump came lose. Reconnect?
The easiest way woud be to go to K/Mart & buy a Crimp&connector set Around $8.00 In the auto section They have instructions on how to do what you want to put a new end on the wires.(in the auto section).Hope this helps Kind Regards Stefan.
Jul 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer will not drain (nd help code)
I found that one the plastic features on the bottom of the pump housing that mount the pump to the sheet metal floor of the washer had broken off. This allowed the pump to move around during opperation which cause the power connections to become loose and have intermitant contact. I cleaned up the connections and used shills to tighten up the pump mount and it works fine. Pretty dissapointing to pay a "qualified" technician to come and overlook such a simple problem and tell me to buy a new board :(
May 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water will not drain
First, check for blockages.
Check the bottom of the washer for any broken glass, paper, plastic etc that can be blocking the drain.
Then check the hose and where it dumps into the homes main drain system.(Typically found under the sink attached to the garbage disposal or drain off the sink basin)
If the garbage disposal is bad or clogged, it can cause the DW to not drain as well.
If you have no blockages, then you likely have a bad pump.
If that's the case, check to see if the unit is under warranty.
If not, it is not uncommon for the cost of replacing a pump to approach the cost of buying a new washer. Especially if the washer is quite old or a near base model.
The parts alone typically cost 60 to 120 bucks. If you have to pay a tech to perform the labor, expect to pay between 175 to 275.
It is much easier to replace a DW than it is to replace the pump. So if you are unfortunate enough to have a bad pump, my advice would be to buy a new washer, and install it yourself.
I will be happy to help you with that as well.
(It's basically two hoses and three wires.)
Please don't forget to rate this solution.
Dec 26, 2008 | GE Nautilus 24" Built-in Dishwasher
Same problem
ck lid switch blocked pump would not prevent spin unless it was locked up then probably wouldn't agitate either
Jul 20, 2008 | Kenmore 22422 Top Load Washer
Frigidaire Affinity ATF6000F Front Load Washer Logo
14 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
