Question about Optics
Spot hogg wiseguy release
Hook on loop
How do i make a banded treble stitch please
  1. Yarn over hook three times, then insert hook into next stitch.
  2. Yarn over hook and draw yarn through stitch (there are five loops on the hook).
  3. Loop yarn over hook and draw through two loops (there are now four loops remaining on the hook).
  4. Yarn over hook and draw through two loops (there are now three loops remaining on the hook).
  5. Yarn over hook and draw through two loops (there are now two loops remaining on the hook).
  6. Again, loop yarn over hook and draw through the last two loops on the hook (there is now one loop remaining.)
  7. This completes one double treble crochet.
Jan 30, 2015 | PTAJ Marketing Crocheting Stitches
Janome 611 manual com file 634d
upper thread tension needs tightening or timing adjusting.
Dec 01, 2013 | Singer Confidence 7463 Computerized Sewing...
I think timing is correct because hook catches thread every time, but when the hook finishes its rotation and releases the thread, the thread loop doesnt make it all the way around the bobbin case......it...
the catcher/hook on the bobbin case system loosen or not fix properly probably becoz of vibration or something( check or replace new), then check upper system either tension/ tighten of your thread/yarn or correct..
Oct 27, 2013 | Consew CP206R Sewing Machine
How to remove a seat on a 2004 Suzuki Volusia
There's one bolt at the back of the pillion seat, release that and slip the rear seat out of its leather loop. The loop and the front seat are held on by two bolts, with those removed you can slip the driver seat out of its hook under the tank.
Nov 30, 2011 | Suzuki Motorcycles
Cant unlock hook
With the key door open, hold the unit and pull down firmly
on the key door. The door knob loop on top of the unit
will be released.
Pull up on hook while pulling down on open key door
Mar 28, 2011 | Ryobi Tec4 Digital Key Lock Box Rp4310
How to fix a stuck seat belt VW GTI 2009
I just solved the problem for a stuck rear center seat belt in my 2002 Jetta.
Flip the base seat cushion forward against the front seat backs. Trace down along the belt to its tether point on the floor. The belt is sewn around a steel loop. The loop is anchored to a black steel hook. A thin silvery retainer plate is spring tensioned on top of the loop to prevent it from sliding off of the hook when the seat back is folded.
Therefore, you need to press the silvery retainer plate away from the hook (push up) to allow the loop to be slid from the hook. The belt was tight with the seat back in the upright position, so it was necessary to fold the seat back forward to create slack in the belt. Now push the belt loop towards the trunk and slide it off of the end of the hook (only possible with the retainer plate pushed up out of the way).
Now with total release of tension on the system via the bottom end of the seat belt being untethered and with the seat back returned to the upright position, normal extension and retraction of the belt will be reestablished. Next, simply extend the seat belt and slide the loop back into place over the floor hook. It snaps past the silvery retainer plate without all the effort required to hold the plate up during removal of the loop during disassembly.
Check again, the seat belt should be extending and retracting properly. Now just put the seat cushion back into regular position and you will be able to safely buckle up three people across the back seat.
It took about as long to do this repair as it has taken to post this answer to the problem. Note, the seat belt safety mechanism only allows normal extension and retraction of the belt when the seat back is upright.
Nov 29, 2009 | Volkswagen GTI Cars & Trucks
My Kenmore Elite freezer door came off one of its hinges. I cannot figure out how to put it back on so that it stays. The connection has an upper hook with a lower hinged arm. It is strange.
I just spent the better part of an hour on this. There is a white flange with two phillips screws. If you take this off it is easier to see the mechanism, but you may be able to get it back on without removing the flange. I removed the flange. The mechanism attached to the door has a hook facing up and a smaller hook facing down. There is a hinged metal bar below this. The bar has a hinged piece with a loop on it. Pull the loop up. Now push down on the piece with the hooks ( it has a spring) and hook the smaller hook on the loop. Do this for both sides. Now the door should slide easily into the slots. Once in the slots, push down on the hook piece and release the loop. Push the loop back in place along the bar. Hopefully this does the trick for you, it did for me.
Oct 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do you use the needle threading device
To the left of the top of the needle there is a little lever. Make sure the needle is all the way up by turning the wheel. Pull the lever down and a hook will go throught the eye of the needle. Place the thead across the hook and release the lever. You should have a loop of thread coming out the back side of the needle. Pull the loop and your needle is threaded.
Oct 05, 2009 | Bernina Artista 180
How do i take off the parking brake off a 1991 buick regal
push on the parking brake pedel, you push on it to set and also release it.
Oct 01, 2009 | 1991 Buick Regal
Timing problem on Rex commercial blind stitch
retime your hook with relation to your needle the hook is slightly out of time causing it to "slip the loop" the hook should hold the loop until the needle retracts forming the chain
Apr 30, 2009 | Rex RX-518
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
