Question about GE JES1142SJ Microwave Oven
Jes1142sj over heated and shut off
Heating element does not shut off even when microwave is off
All electronics that have relays have a problem with the relays arcing shut. Hit the back of the relay firmly to release it.
Nov 28, 2013 | LG LMVM2277ST Microwave Oven
Bosch hmb5050 shut down after 30 seconds
It may be turning off because it is not heating, does it have the lights inside and the turntable both working?
Dec 10, 2012 | Bosch Microwave Ovens
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
Microwave shuts off when in heating mode
hmmm its capaicitor burned!!!! its heats more on nrmal heating!!! and shuts off ,,,,,,,,,,,,,, repair tht inner capacitor
Nov 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not heat.
HI, this is an inverter board issue. the magnetron would not shut down the unit. if the magnetron was the issue, it would continue to run but, it would not heat.
replace the inverter asap.
Jun 17, 2009 | Panasonic Microwave Ovens
Over the range MV Oven shuts down from heat
it is triggering the overtemp switch. try to check the vent outlet, it could be clogged with dirt. or the cooling fan of the magnetron is no longer running. could be stuck up because of not being used for a long time.
Feb 20, 2008 | Microwave Ovens
My microwave heats but shuts off due to the fan not coming on
A little late for a reply; you probably have replaced it by now.
I suspect it shuts down because the fan is no longer turning on and there is probably a thermal shutoff switch near or on the magnetron to prevent the chance of fire.
Jan 08, 2008 | GE JVM1190 Microwave Oven
White Panasonic
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Nov 09, 2007 | Panasonic NN-H764 Microwave Oven
Panasonic NN-S533WF Microwave
because of high voltage circuit thats happend ,please check highvoltage circuit may be short circuit or any companent burntout. check magnetron and high voltage diodes etc.
Sep 29, 2007 | Microwave Ovens
GE JES1142SJ Microwave Oven Logo
24 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
