Question about Toshiba BDX5400 Blu-Ray Disc Player/3D/Wifi
My toshiba bdx5400 wont connect to netflix
Says 82% connected to wifi why wont it connect says connection failed
Chillimar
  • 117 Answers
SOURCE: Toshiba Satellite A200 WiFi connect range extremely limited
Try to download latest wireless drivers for your A200 from here
Posted on Dec 10, 2008
sys_admin
  • 829 Answers
SOURCE: TOSHIBA LAPTOP WIFI PROBLEM
Hi , It seems your Wifi is not having problem but the issue lies with the internet connectivity , What browser you try to use , Try using mozilla and then let me know
Posted on Jan 14, 2009
Crankstart
  • 696 Answers
SOURCE: wireless function key combination
Usually on the toshiba it is Fn and F2 or F4 the f key will have a coloured picture of an antenna with waves coming off of it.
Also most toshiba laptops have a physical switch on the edge of the case below the keyboard. Make sure that switch is on first then try the Fn and function key combo as they work together like a two way light switch. Both must be on for the card to be active.
Chris
Armor-IT
Posted on Apr 25, 2009
  • 742 Answers
SOURCE: not able to connect wifi in my lapopo
In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
Posted on Feb 04, 2010
jomabug76
  • 1148 Answers
SOURCE: toshiba thrive wifi connectivity
u search wifi networks ,,should have in the menu wifi connections or add a new network,,do a search for wifi,,a wifi scan,,when new netwrks or signal s appear on there,,,if it says open u can go online,,if passwrd enabled or wep or psk or whatever u cant ,,has to be a open signal,,like mcdonalds,,hotels,,,stuff like that,,drive an d search,,
Posted on Dec 23, 2011
I have a toshiba dvd blue ray player up to 3 days ago was quite happily watching Netflix now it won’t load. I can get everything else but Netflix. Please help
Sounds as if your player has lost its internet connection. Check the cable if it's wired, and the WiFi setup if it's wireless.
Feb 02, 2018 | Toshiba Televison & Video
When tv is turned on and I press button for netflix, netflix says it can't connect. Why?
This means that your WiFi is not properly setup. Check your router's WiFi, TV's WiFi, proper passwords, etc. You must connect (wired or wirelessly) your TV to your Internet before Netflix will work.
Jan 03, 2018 | Computers & Internet
I want to install netflix on my tv
Hey, if you have SmartTV you will need to first connect it to your wifi. Once you have internet connection working on the TV then go to the TV app store and get NetFlix from there. If the TV is not SmartTV then i you wont be able to install NetFlix.
I hope this helps.
Dec 21, 2017 | Computers & Internet
My Toshiba smart TVs model 40L3400u will not turn on or off nor will it go to the home menu. I can't get Netflix to work I've tried everything aside from resetting it which I don't know How to do. Please...
if you encountered that Error message "Your device may not be connected to the Internet. (code: nw-1-1000)" means that you are not really connected to WIFI
** try to do network connection test and check the Wireless information to verify if you are Connected or not
- Set-Up/Menu > Network > network Set-up > Network Connection test
- Set-Up/Menu > Network > network Set-up >Wireless Set-up > Wireless Information
and if shows that you are not connected you can try to Check on to the MANUAL on how to Connect the TV to WIFI
- you can Download the manual on SUpport.toshiba.com
Jan 02, 2015 | Televison & Video
How do I set up Netflix on Toshiba 50L3400U?
MAKE SURE THE TV IS CONNECTED TO YOUR HOME WIFI NETWORK. SEE MANUAL FOR THIS
Dec 16, 2014 | Netflix
My toshiba BDX2700 has an integrated wifi connection. It connects to my home networrk. For 2 weeks it worked just fine and now it won't connect. Or, actually, it says it "connects" to the...
Seems like the DNS on your router has failed to provide address info for your BR player. I would first try this:
  1. Unplug the Blu-Ray player
  2. Unplug your router for 20 seconds
  3. Plug your router back in and wait for the Wifi symbol or WLAN light to turn on
  4. Plug in and turn on the Blu-Ray player
If that fails, I would double check the WiFi settings on the Blu-Ray player, make sure that you have the SSID and passkey correct.
If that still fails, I suspect that your router's DHCP table has a problem with it. You may need to consult your router's manual for instructions on how to clear the DHCP table. The easiest way to do this is to perform a factory reset on the router. You will have to redo any configurations you may have applied to the router such as WiFi name (SSID) and pasword.
Mar 13, 2011 | Toshiba BDX2700 Blu-Ray Player
I have the Insignia NS-WBRDVD2. My problem is with the internet connection. It says I am connected...but it also says "timeout" on the same screen. If I try to go to Netflix, it tells me I am...
I have the exact same problem. My blu-ray player was working about half an hour ago and now suddenly it is telling me "Your BD Player does not seem to have a properly configured internet connection, which allows features such as BD-Live, Netflix and software update notifications. [Press the] red button to configure the network connection."I do so and it connects to my wifi connection but wont allow me to use CinemaNow, Netflix, or Pandora. My wifi is working perfectly normal on my laptop at the moment. I don't know what happened. One minute I'm streaming a movie on CinemaNow and now it wont cooperate with my wifi at all.I was wondering if maybe you solved your issue (considering you posted 5 months ago) and if you could possibly give me any advice??
Mar 09, 2011 | Televison & Video
The Netflix app on my vizio svt422xvt (one of the Vizios with VIA internet & wifi built-in) won't connect to Netflix. It directs me to the Netflix website for help, but Netflix help tells me to...
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
Aug 11, 2010 | Televison & Video
Toshiba BDX5400 Blu-Ray Disc Player/3D/Wifi Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
