Question about Vision Fitness T9200 Treadmill
Motor stopped Fuse blown in service panel. Council. Lights but motor will not operate
All power windows not working in 1996 ford contour how do i find problem
The lights are on a different circuit than the motors. Check the fuse panel. It's a 40 amp fuse in position 21 in the fuse panel under the dash. Across the bottom of the panel are two rows of fuses. It's the third fuse from the left on the top row.
If you find the fuse blown, replace it and check the window operation. If it blows again almost immediately, then you'll need to get the car looked at by a shop, unless you are really familiar with electrical trouble-shooting, and have wiring diagrams for the car.
Oct 04, 2014 | 1996 Ford Contour
Does a 1994 Chevrolet Silverado c1500 have a fuel pump
Yes, it has an electrical fuel pump located in the gas tank. First check the fuel pump fuse located in the fuse panel on the left outer side of the dash. You can only access this panel with the driver's door open. It is located near the black button for the dome lights and chime.
It is a 20-amp fuse. Replace it if it is blown, but ONLY with a 20-amp fuse. The wire harness for the fuel pump sometimes goes bad, or the pump motor, or the wire harness inside the tank to the pump motor. If the blown fuse is replaced with a larger-amp fuse, you could cause a fire or explosion.
If it blows the replacement fuse, stop. Fuses blow for a reason, 9 times out of 10. Call a tow truck to remove the truck to a qualified repair shop.
Sep 12, 2014 | 1994 Chevrolet C1500
My 1996 Toyota Camry's back-up lights are out, bulbs are fine. A blown fuse? The driver's manual directs me to the passenger side kick panel. Where do I find this and how do I remove it to get
Look on the shift linkage,shift cable or the transaxle,
for a back up switch
Call or stop by a dealer & walk in the back service bay,
from the outside & ask a tech were the sw is
Jun 12, 2012 | 1996 Toyota Camry
Tail lights and instrument panel lights stopped working, no apparent fuse blown
If your absolutely positive fuse is not blown, I'd replace headlight switch. H/L switch powers dash lights and tail lights.
Feb 25, 2011 | 1995 Ford Taurus
Duet dryer doesn't run. control panel lights up. push on button and all you hear is a click. what do i do?
No dryer function works when the motor cannot run and the common issue is a blown thermal fuse located on the blower housing and wired in series with the motor. There will be no power to the motor when the thermal fuse blows and the motor cannot therefore run. Bypass the thermal fuse and if the motor runs, the thermal use is indeed blown and needs to be replaced. Do not use the dryer with the thermal fuse blown due to fire hazards.
Disconnect power then open the dryer door and remove the lint filter. Remove the screws from the toe panel and remove the panel. Remove the screws securing the lint duct and remove the duct.
The thermal fuse can now be bypassed or replaced if necessary.
Bypass the thermal fuse by disconnecting the wires and taping them together or jumping a wire between them. Once done, plug the dryer in then start it. The thermal fuse is indeed blown and needs to be replaced if the dryer runs. The thermal fuse is part number 3390719. Reassemble the dryer in reverse order of the disassembly steps.
Oct 10, 2010 | Whirlpool Dryers
Blower not operating
You can check the fuse panel for a blown fuse. Replace blown fuses with the recommended fuse only. Its not safe for your car or you, to switch them to a different size. Be sure that your ignition is in the off position and take the keys out before you change any fuses. If its not a blown fuse, you could have a blown fan motor or faulty wiring but I'd start with the fuse box.
May 09, 2010 | Cars & Trucks
Instrument lights do not work
yes--instr panel fuse. Also check the brake light (STOP) fuse. Sometimes a blown brake light fuse sends you a thought through NO DASH LIGHTS
Apr 02, 2009 | 2003 Chevrolet Impala
My kitchen aid dishwasher was running on the normal clcle then all of a sudden it stopped. No lights operate on the touch panel.
most likely cause, is a blown fuse on the control panle, with a torx 15 screwwdriver you can remove the control lpanel accessing hte control board, on it youll find a small white rectangular fuse with 2 wires attached to it, it more than likely has blown you can find the part on sears.com probalby 20-40 bucks.its live wires leading to one side of fuse so unplug/disconnect power before servicing... ill bet that theres water remaining on the floor of dishwasher as well?? common place in cycle to blow!
Dec 17, 2008 | Dishwashers
Changing fuse on Nutone Allure Ws2
Hi Mertl, I sure hope you found the solution since, but I am posting the answer for other people like me (and you) who need to find it !
The service manual says:
To replace the fuse:
1. Disconnect power at service entrance.
2. Remove filters, bottom panel, light wire harness, and air chute.
The fuse is actually right behind the fan controls, so to access it you need to disassemble everything that's in the way.
BTW, for anyone wondering if it's the fuse that's faulty, here's a clue:
If the fuse has opened (blown), the green fan-level indicators
will operate properly when the fan buttons/switches are pressed
- but the fan and lights will not turn on.
The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
Good luck all !
Aug 16, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Vision Fitness T9200 Treadmill Logo
46 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
ray gallant
Electro Med Services...
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
