The connection to the server has failed. Account '<account name>', Server: '<SMTP server name>', Protocol: SMTP, Port: 25, Secure (SSL): No, Socket Error: 10051, Error Number: 0x800CCC0E
To resolve this behavior, change the SMTP server for your e-mail account to use the MSN SMTP server. To do this:
1.In Outlook Express, click Accounts on the Tools menu.
2.Click the Mail tab, select the account that you want to change, and then click the Properties button.
3.Click the Servers tab.
4.Under Server Information, delete the entry that is in the Outgoing mail (SMTP) box, and then type smtp.email.msn.com.
5.Under Outgoing Mail Server, click to select the My server requires authentication check box, and then click the Settings button.
6.Under Logon Information, click Log on using.
7.In the Account name box, type you MSN Member ID (everything before the at sign (@) of you MSN e-mail address).
8.In the Password box, type your MSN account password
9.Click to select the Log on using Secure PasswordAuthentication check box.
10.Click OK to close the Outgoing Mail Server dialog box.
11.Click OK to close the <Mail Account> Properties dialog box.
12.Click Close.
1:In Microsoft Outlook, select Tools > E-mail Accounts. 2: On the E-mail Accounts wizard window, select "Add a new e-mail account" and click Next. 3: For your server type, select "POP3" and click Next 4: On the Internet E-mail Settings (POP3) window, enter your information as follows: Your Name Enter your first and last name. E-mail Address Enter your e-mail address. User Name Enter your e-mail address, again. Password Enter the password you set up for your e-mail account. Incoming mail server (POP3) Enter pop.secureserver.net for your incoming mail server. Outgoing mail server (SMTP) Enter smtpout.secureserver.net for your outgoing mail server. 5: Click “more settings”. On the Internet E-mail Settings window, select the "Outgoing Server" tab. 6. Select "My outgoing server (SMTP) requires authentication." 7. If you did not change the SMTP relay section, select "Use same settings as my incoming mail server". If you changed the user name and password in the SMTP relay section of your Manage Email Accounts page, select "Log on using" and enter the user name and password. The following example assumes you did not change your SMTP relay section in your Manage Email Accounts page. 8: Select the "Advanced" tab and change the "Outgoing server (SMTP)" port to 80 or 3535. 9: Click OK. 10. Click Next. 11. Click Finish.
If you are using email like OutlookExpress, or Windows Mail, you may have linked to multiple email address' . So when you hit Send / Recive, its checking 2 or more email adds.. If so, one of them is not setup correctly for the Outgoing server. When you create a new email, it uses your default main email address, which is apparently setup correctly. When you reply to a mail which came in on the "other" account the outgoing server setup is wrong, resulting in the message you recieve.
You should go over the server setting for each account other than your default email account.
No worry susan! your mail date/time settings and system settings are different, so change these settings in your mail at an early by selecting timezone! have fine!
For the email:
Configuring Microsoft Outlook / Outlook Express for Dataone:
1.
Open Outlook Express --> Click on Tools --> Click on Accounts
2.
Click on Mail --> Click on Add -- Click on Mail
3.
Fill - Display Name: e.g. A K Sharma
4.
Click on Next --> Fill - E-mail address: e.g. [email protected]
5.
Click on Next --> Select My Incoming Mail Server is a POP3 Server
6.
Fill - Incoming Mail (POP3) Server: e.g. wmma.dataone.in/smma.dataone.in/nmma.dataone.in as allotted by Node-Incharge
7.
Fill Outgoing mail (SMTP) Server: e.g. wmra.dataone.in/smra.dataone.in/nmra.dataone.in
8.
Click on Next --> Fill - Account name: e.g. [email protected]
9.
Un-tick Remember password --> Click on Next
10.
Click on Finish --> Select the Account --> Click on Properties --> Click on Servers
11.
Tick My Server requires authentication --> Click on Settings
12.
Ensure that Use same settings as my incoming mail server is selected
13.
Click on OK --> Click on Apply --> Click on OK --> Click on Close
13.
Back Configuring Netscape Messenger for Dataone:
1.
Open Netscape Messenger --> Click on Edit --> Click on Preferences
2.
Click on Identity (under Mail & Newsgroups) --> Fill - Your Name: e.g. A K Sharma
3.
Fill - Email address: e.g. [email protected]
4.
Click on Mail Servers (under Mail & Newsgroups) --> Under Incoming Mail Servers - Click on Add
5.
Fill - Server Name: e.g. wmma.dataone.in/smma.dataone.in/nmma.dataone.in as allotted by Node-Incharge
6.
Select Server Type as POP3 Server --> Fill - User Name: e.g. [email protected]
7.
Click on OK --> Under Outgoing Mail Server Fill - Outgoing mail (SMTP) server: e.g. smra.dataone.in/wmra.dataone.in/nmra.dataone.in
8.
Fill - Outgoing mail server user name: e.g. [email protected] --> Click on OK
it shouldn't have anything to do with the router, the ports for emails are automatically opened and allowed by windows, assuming you are using outlook or similair you should not have been able to send emails using another connection as you would have to change the smtp settings to send mail through the connection server, in this case if you have a internet security programme you may find it is checking outgoing mail for viruses and sometimes they get put in your outbox and never sent, if this is the cas dissable scan outgoing email in your security software.
If you are sending mail through your online mailing web page eg. hotmail then there is a problem with the e mail you are sending perhaps too large a file or a file that requires you to zip it for security reasons.
