Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
Heater run hot then cold
Already replaced the thermoral regulator Gets hot water for a couple of mins. Then cooler water, them back and forth.
    Top Expert:
  • Sta Rite Master
  • 5,056 Answers
Check gas pressure if ok check flame sensor if ok check high limits
Posted on Jun 11, 2016
Why would 2002 ford ranger 3.0L temp guage stay on extreme cold after water pump replacement?
i would think there is an air lock in the coolant system , have you run the engine whilst at stand still and opened the heater control to the hot position and leave to run for 10 mins or so , let cooldown then check coolant level
Oct 11, 2014 | Cars & Trucks
On demand hot water heater gets cold for a short while during showers.
Check for crossover.
Bad single-handle faucet cartridge causes cold water to enter hot pipe, so hot never arrives and tankless does not run consistAntly
http://waterheatertimer.org/Crossover.html
Apr 13, 2013 | Bosch AquaStar 2400ES-NG
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
My 1995 honda heater is blowing cold air.it wont blow hot.i changed the heater control valve.what am i to do.
try back flushing your heater core find the 2 hoses to the heater and start the motor let it run for a bit feel the hoses 1 should get hot and 1 should be a little cooler the 1 that gets hot is the inlet and the cooler 1 is the outlet remove them after the motor has cooled down and use a garden hose to back flush the core flush water through the outlet you dont need to use high pressure if you do there is a chance the core can crack and leak.
Dec 30, 2010 | 1995 Honda Accord
Water tempeture gets hot then cool
Have you tried turning off the valves to the water heater and making sure you have no water flow out of the hot water tap? When this happens, often it is because of a problem with a shower cartridge allowing the cold water to cross over into the hot water side. It makes the unit think that the flow has reduced and the heater will turn down or shut off. Then things bounce back and forth Hot to Cold then back to Hot.
Mar 28, 2010 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
HEATING PROBLEMS
Need more information. The most important thing would be to watch the heater water valve move when someone turns the control from hot to cold, back and forth?
Heater valve controls tend to be operated by vacuum, and switched by a heater computer. Lots of possibilities. But first tell us what you see move when operated? Valve is usually in engine compartment, in the heater hose. Follow the hot one.
Jan 03, 2010 | 1999 GMC Sierra
03 Buick Rendezvous Overheating
If the top hose is hot and the bottom is cold, your definitely not getting circulation. You,ve already done alot of work to this vehicle so you have pretty much answered your own question. About the only thing left is the heater core. Of course, I dont want to be the one to tell you it is definitely the heater core because obviously I am not looking at the vehicle. But If i was a betting man, thats where my money would be.
Dec 14, 2009 | 2002 Buick Rendezvous
Low pressure on hot water taps and showers
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
May 24, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
99 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
