Question about Stamina Products Stamina Pro 5300 Silent Magnetic Resistance Upright Bike
Replace broke belt - Stamina Products Stamina Pro 5300 Silent Magnetic Resistance Upright Bike
Broke timing belt
If the timing belt broke, your car won't run. Fortunately, it's not too expensive to replace, and as long as you are at it, may as well replace the water pump. Usually they have to dismount that in order to get at the timing belt. Generally that is that case, but it all depends on how each car is set up.
Oct 03, 2013 | 1996 Toyota Camry
Replace drive belt 98 lumina w/o fixing a/c compressor?
Yes as long as the a/c pulley spins freely. You should be able to spin all pulleys by hand, except for crank pulley
Apr 03, 2013 | 1997 Chevrolet Lumina
Serpentine belt broke is the engine ruined
serpentine belt no timing belt maybe yes know as a interferece engine but the serp.. belt should be fine just replace
Dec 29, 2010 | 2000 Ford Escort
The timing belt broke on my 1986 Toyota Camry 2L gasoline engine 2SE, manual transmission while cruising around 45mph on the 5th gear (around 145 kmiles). Is that an interference engine, should I expect...
It is possible you could have bent a valve when the timing belt broke off without a warning.
In this kind of engine, whenever the timing belt broke off, it takes a valve with it-possibly the number three valve. That is why it is a good practice to always replace these belts together with the water-pump at every 60,000-miles or a little after.
It takes about 4-6-hours to replace these two items. And on your car, it could be replaced by a determined and mechanically inclined person.
Dec 21, 2009 | Cell Phones
Engine cooling belt broke. lookin for tips on
Here is a link to a set of videos about how to replace your serpentine belt. http://www.wonderhowto.com/how-to/video/how-to-change-a-serpentine-belt-on-your-car-39904/
It's important to know the routing of the new belt when you replace it. There should be a routing diagram in the engine compartment near the top of the radiator. If you don't see one, you can use this diagram as a guide...
Nov 26, 2009 | 2001 Hyundai Sonata
Just broke timing belt on my 300zx,does thi
Yes your engine is a interference engine,
which mean valve to piston hit.
But replace the timing belt.
Possible you didn't bent a valve.
Depend on the condition when the T/B broke,
Let me know.....
Sep 29, 2009 | 1985 Nissan 300ZX
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
1995 ford taurus,broke bolt on tensioner pully while trying to replace belt, now what??
was this the bolt in center of the tensioner pulley? if so you will need to remove and replace the tensioner assembly, if not which bolt did you break?
May 26, 2009 | 1995 Ford Taurus
The serpentine belt broke replaced it and i broke
a bad belt tensioner leaving too much slack in belt causes it to break.
Apr 01, 2009 | 1997 Volvo 850
Stamina Products Stamina Pro 5300 Silent Magnetic Resistance Upright Bike Logo
Top Stamina Products Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Stamina Products Cycling Expert? Answer questions, earn points and help others
