Question about KitchenAid KUDS30FXSS Builtin Dishwasher
How to get to control panel
Need to get to control panel to test to check voltage
2 Suggested Answers
blackmar
  • 235 Answers
SOURCE: Range Model YKESC307HWO: Received Voltage
It sounds like the control board of the timer is faulty. Do you need the electronic timer/clock. If you don't it is normally easy to by-pass the timer altogether. Find the main active wire coming into the timer. Then identify the load wiring which runs from the timer to the oven thermostat control. These two wires simply need to be connected and the timer is bypassed and the oven will work.
Posted on Feb 13, 2011
2006 Chevy Silverado 5.3 Code B2610
DTC B2610
Circuit Description
The body control module (BCM) receives a variable voltage signal from the instrument panel (I/P) dimmer switch requesting to illuminate the illumination lamps to a desired intensity. When this occurs, the BCM directly sends a variable voltage based on the I/P dimmer switch position on the instrument panel lamps dimming supply voltage circuit, instrument panel lamps dimming control circuit, and the LED dimming signal circuit.
Voltage for the instrument panel lamps dimming supply voltage circuit, instrument panel lamps dimming control circuit, and the LED dimming signal circuits is from the TBC 2 A fuse in the instrument panel fuse block directly through the BCM to these circuits.
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Is the TBC 2 A fuse in the instrument panel fuse block open?
YES - Go to Step 3
NO - Go to Step 4
Test the instrument panel lamps dimming control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 11
NO - Go to Step 8
Test the instrument panel lamps dimming supply voltage circuit and the instrument panel lamps dimming control circuit for an open, high resistance, short to voltage or short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 11
NO - Go to Step 5
Are you confused yet ? The info above is a Chevy factory repair manual diagnostic flow chart for DTC B2610 . Your best bet would be to take your vehicle to a qualified repair shop .
Aug 14, 2016 | Cars & Trucks
Direct spark ignition wont fire on bake or broil
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The infinite switch
Apr 05, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
MY GE MICROWAVE WON'T HEAT
check every step and fix it God bless youOK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
mwswitchtest2.jpgIf the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.
Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode.Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
Microwave Runs, Heats, but turntable does not move This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Apr 02, 2013 | GE Microwave Ovens
Opened door ,oven light blew out,turntable motor stopped also noticed power button next to timer button shows nothin when you try it. but you can put in cup of coffee it will heet up.
Apr 02, 2013 | Microwave Ovens
Cplmv169dc
see this steps and fix it. God bless you
First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Magnetron what is problem?
However see the table for test it.
Oct 04, 2012 | Electrolux Microwave Ovens
Food Heats fine, but turntable wont rotate. Makes a loud noise until we press the
see this tips for to repair:
Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly.
Sep 09, 2012 | GE JVM1860 Microwave Oven
Goldstar under counter microwave spindle won't turn
use the common sense, and logically, fix it. God bless you
Aug 02, 2012 | GE Microwave Ovens
TURN TABLE NOT ROTATING
see the nex step and proceed with common sense and logically: God bless you
Jul 26, 2012 | GE Microwave Ovens
Replaced the touchpad and put it all back together. It now heats, but the oven light doesn't come on and the turntable doesn't rotate. Do you think there's a loose wire?
First check is the main fuse of the unit. On countertopunits, you will need to take the shell off. The fuse will be close to where thecord comes through into the unit. OTR units, this main fuse is usually behindthe control panel or possibly behind the vent. Usually the fuse is obvious ifblown, otherwise test with an OHM meter, if open, replace fuse. Some brands will also have a thermal cut-off fuse in theincoming voltage line to the control board. This thermostat looking fuse isusually above the oven cavity somewhere under the outside shell. Sometimes youcan get to it through the vent of OTR models. Test with an OHM meter, replaceif open. Forturntable: First, make sure the turntable coupler under the glass dish is notbroken. Second, on the control board, find the turntable relay and test forvoltage. Some turntable motors are 24 volts DC, so make sure you're testing thecorrect voltage. If no voltage from the control board, then replace the controlboard. Otherwise head towards the turntable motor. On OTR models, you can get to the motor by un-screwing thebottom panel on the microwave. On countertop models, there will either be aknockout or screw on access panel. Check for voltage at the motor. If novoltage, check the wiring back towards the control. If voltage, then replacethe turntable motor. Hope this will help you. Good Luck.
Sep 03, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
I have no air hot or cold coming out the vents. i removed the blower motor and it spins ok. everything in the panel lights on but no air is coming out. i can hear the ac kicking in and out.
First check fuse 103 in the battery relay box and swap the blower relay with another similar relay, such as the horn relay. If this isn't the problem, you should hot wire the blower motor to the battery to make sure it works. If all of that is good, next check the switch/motor controller. Take the connector off the blower motor and check the voltage in the connector. With the key on, the voltage should be 12 volts with the fan setting on high. You can also use a 12 volt test light for this test. If there is no voltage, replace the switch/controller at the control panel. If you need any instructions or have any questions, please get back to me.
Nov 05, 2010 | 2004 Mercury Grand Marquis
KitchenAid KUDS30FXSS Builtin Dishwasher Logo
52 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
