Question about Broan NuTone RMDD3604 36 Inch Rangemaster Downdrafts, Stainless Steel
Broan rmdd3604 downdraft blower will not turn off
Keeps going up and down without turning off
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
Piezo goes off every 10 seconds.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 10, 2010 | Whirlpool SC3017RQ 30 in. Gas Cooktop
After cleaning the electric starters keep trying to light without being turned on. When i actually attempt to light the burners they are not lighting.
unplug the range untill the switches dry. Water will make the switch to actavate the spark ig. water will also cloge the holes in the burrner heads.
Oct 31, 2009 | Cooktops
Knob wont turn on
Push down and to the right to by-pass the safety feature designed to keep the kids from turning it on and those who are new to the feature.
Jun 12, 2009 | Jenn-Air JGD8345 Gas Cooktop
What's best tu glue my cooktop on my granite countertop?
I don't think I'd glue it down permenantly. I just had to replace the ceramic glass on mine (a JED 8430 ABD) after it cracked. Thankfully, it wasn't glued down so I could replace it pretty easily (ordered part directly from Jenn Air). But some sort of seal to keep food out from under the cooktop would be nice. I just wouldn't go permenant. The fact that you have to tape the down draft to the external vent should keep the cooktop in one place (plus its own weight).
Feb 28, 2009 | Jenn-Air JED8430 Electric Cooktop
When the large burner is on, it keeps trying to ignite
Check that the burner orifice nozzle (the round thing that comes off) is properly seated on the burner manifold. Mine have a tab that must interlock.
Make sure all your burner orifices are CLEAN. Scrub them with a plastic kitchen scrubber, soap and water.
The way this works is, when a burner is turned on, the sensing mechanism for the spark control reads the ionization of the flame. No flame, no ionization, keep sparking so gas buildup is minimal in the area before a flame is ignited. )Kinda like the spark thingy's underneath the shuttle, without the ionization sensor's, just before it launches.).
Jan 14, 2009 | Dacor 36 in. EG366SCHLP Gas Cooktop
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Raised vent system won't stay in down position
sounds like yo u have a faulty home switch. when dropped to lowest setting it should switch off electric. however if switch is bad never senses its down adn thenwants to open back up. there should be an acces panel in lower right corner of unit along witha wire diargam
Mar 08, 2008 | Cooktops
Broan NuTone RMDD3604 36 Inch Rangemaster Downdrafts, Stainless Steel Logo
103 people viewed this question
Top Broan Cooktops Experts
Paul Carew
Are you a Broan Cooktop Expert? Answer questions, earn points and help others
