Question about GE Spacemaker JVM1640SJ Microwave Oven
Smell in the fridge
I have cleaned the fridge a number of time and the freezer comparment still has an unpleasant oder. Even the Ice takes on the flavor of the order. What can this be. Is about 13 years old.
  • GE Master
  • 9,098 Answers
There are many good suggestions for cleaning and deodorizing microwaves here, and many of the tips will work for refrigerators, too.
Posted on Jun 16, 2009
My lg fridge freezer has stopped freezing since yesterday, model number gwb207flqa. help all my food is defrosting. even the fridge side isnt cold.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 27, 2011 | Microwave Ovens
Hi, I have a amana fridge with freezer on the bottom. It has an ice maker and water dispenser. The big problem is a buzzing noise comming from the fridge, it start aprox every 16 min and buzzes for 10...
The buzzing you hear is the water valve trying to run water to the icemaker. If there is no water going to the icemaker it will be going into cycles one after another. And when it does it adds heat into the freezer. Turn the ice maker off and see if the freezer gets colder.
May 20, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
My Panasonic refrigerator NR-B420T is not cooling, however the freezer part still cooling.
Top of Form
Since there is cooling on the freezer the fault can be the defrost timer. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Jan 05, 2011 | Panasonic Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
We have a Hotpoint refrigerator/frezzer. It intermittently makes fan noises and stops making ice. Where do we find someone who can service the unit?
I hope your microwave doesn't make ice !!!
Are you in the GTA (Greater Toronto Area). If not I can tell you what is happening.
All fridges have a timer so that the freezer goes thru a defrosting mode for about 3hrs
In that 3hrs there are hearter in the walls of the freezer to melt the ice.
As the ice melts , there is a drain from the back of your freezer down to the bottom of the fridge is a vaporator tray. The hose could be blocked and the water can't drain and after the defrost mode all that water changes to ice and it stops the fan
Take the time to make sure that hose is fre from abstruction
Jul 14, 2010 | Microwave Ovens
My freezer is working but the rest of the fridge is hot
Hi, it is possible for your freezer to work when you fridge is not working. Fridge-freezer appliances have independent controls which can malfunction separately. If your freezer is fine and your fridge seems down, there are several things that could be wrong but what i suspect is that... You should check the damper door located between the freezer and fridge compartments to make sure it opens and closes, sometimes they get an ice build up there and this causes them to stick shut, remove ice with hair dryer or remove and device and replace this will solve your trouble.
Best of all is to call in a local fridge technician around to get it fixed, it won't cost you much...
Take care
Feb 18, 2010 | Magic Chef Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
32 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
