Question about Music
Leslie 122 fuse
Having problems finding a 1.5amp 125v fuse,what is a good substitute rating or size?
6.3 amp 250 v fuse for board
Specify the full fuse ratings please. Internal fuses come in all shapes and sizes.
Jun 16, 2017 | Behringer Music
Hammond organ c2 hook to a 147 leslie speaker it keep blow the 1.5 slo blo fuse how do I fix this
Like all the past answers, make sure everything is clean and lubricated expecially on the Lesley if it's a motorized rotating speaker, the slow blow fuse is telling you there is a problem ?
Feb 22, 2015 | Music
Chrome knobs, can't read them. substitute?
Pain isn't it? Finding compatible knobs is a problem... often they are odd shaft sizes and reaches.
CONSIDER this... remove and paint them with flat black paint and then paint a stripe where the original black on is... guaranteed compatible fit, and you can get the job done in a couple hours for paint to dry. You MAY have to lightly sand the knobs to get paint to stick but that shouldn't take long... try one first as chrome doesn't take paint very well.. If the knobs are metal thoughout, you can just take a hacksaw blade to cut where the line is to expose the metal as the pointer line. The knobs are probably sputtered plastic though...
Feb 06, 2011 | Peavey Bandit 112 Guitar Amplifier With...
Hye. When i switch the on button, the power indicator didnt turn on. Is it because of the tubes or the transformer?
Most likely you blew a bus fuse. Can't say you should open it up and replace it though because there are lethal voltages inside of your amp that could hurt or kill you. You can find replacement bus fuses at radio shack. just make sure you get the same rated fuse. 500mA 125v or something like that in small writing on the metal part of the tiny glass cylinder.
Dec 11, 2010 | Orange Amps Orange Amplifiers TT15C Tiny...
SPEAKER FOR LESLIE CABINET,HAMMOND B3,WHICH WIRE IS POS AND NEG AT SPEAKER
Here is the best source of thee info you need:http://theatreorgans.com/hammond/faq/mystery/mystery.html Take time to read the entire thing as there is plenty of good info.
Oct 18, 2010 | JBL Music
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
What is the fuse rating for a Marshall MG30dfx?
According to the schematic, the fuse for 120 volt is a 1 amp.
This is a reasonable size for this size amp.
May 13, 2010 | Marshall Music
User's manual for the Lowrey Organ Holiday Deluxe w/Magic Genie?
Here is a site to download manual:
http://www.lowreyforum.com/lowreymanuals.htm
A Leslie is special speaker system that is spun to break up the sound so it doesn't seem to come from a single point.
Sometimes the Leslie speaker is in a seperate cabinet fromthe organ, and SOMETIMES it is a simulated Leslie that is done with multiple speakers and electronic switching. If the Leslie is an external one, it usually attaches via a cable that often has either 9, 11, or 13 pins.
Dec 06, 2009 | Music
Adjust modulation speed.
I dont believe there is any way to change the speed. It would NOT really sound like a Leslie anyway as a simple tremelo has no spatial movement, only amplitude change.
Jul 06, 2009 | Alesis Music
Replacement substitute for Fender Sunn power transformer 28-4150
I can't find a schematic that references the transformer and cannot find a replacement either. I'd contact Fender for a reccomended substitute.
Jun 22, 2009 | Music
Music Logo
19 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
