Question about Klipsch G17 Air Wireless Airplay Speaker System
I cant connect to my Klipsch G17 air
Trying to set it up to new home network and computer won't connect
Where is the network security key
The network security key is set by the user when the home network is setup. It prevents people from stealing your wireless signal. If you have forgot it, or didn't set it up but it still is asking for one, you can unplug and hit the reset button on your router and delete the home network you have on your main computer. From there, just run the network setup wizard from the main pc and set your network security key to something you can remember as well as write it down. Then you should be set to add any other pc to your home network as long as when you try to connect, you put the correct key in.
Sep 28, 2012 | Belkin (F5D7231-4) Wireless Router
Find ssid number for linksys model wrt54g
SID broadcast allows computers to quickly locate a new network and connect to it. In wireless home networks computers often use only the home network, which makes SSID broadcast unnecessary. Disabling SSID broadcast adds a bit of security to your wireless network, because computers won't be able to see your network's SSID.
Log into the router.
  1. Open your webbrowser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. Type your login info in the login screen. Default: 'admin' (without quotes) in both fields.
  3. Go to Wireless > Basic Wireless Settings 'wireless
  4. Set SSID broadcast to 'disable'.
  5. Click Save Settings.
On the next page you will set a router password to prevent unwanted visitors from accessing your router setup.
Sep 23, 2011 | Linksys Wireless-G WRT54G Router
My new LG P970 won't connect to my home wifi network. I've spent hours trying to get it to connect without success.
Go to settings, wireless networks, access points and then hit menu button then add access point and enter same address as the one that you are currently connected to then select the access point you just made and problem should be solved, reason why is there was a default proxy, this should fix your problem
Aug 14, 2011 | LG Optimus Black Smartphone
Will not connect to remote wireless WRT160N
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Also this router has issue with the Firmware. Try to upgrade the firmware of the router.
Click here for step by step instructions
Sep 25, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
Get stuck changing net settings, ie ssid...
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration2_bing.gif"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING2_bing.gif page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
May 19, 2010 | Sony Playstation 3 (PS3) Console
Cant connect wirelessly as i cant locate AOSS button
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your ps3 using it.
The PS3 does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set devices up in this manner.
1)To use this set up for the PS3 go to Settings>Network Settings> Internet Connection Setting> (Method) Custom> (Select Connection Method) Wireless- (WLAN2_bing.gif Setting) Auto - AOSS. At this point the PS3 will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
Again this only works if your router has this button. and it is not found on your ps3
so you'll need to set it up differently. if your home is set up with wireless router and your computers are connected online wirelessly read along....
1) go to Settings
2) Network Settings
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
May 18, 2010 | Sony Playstation 3 (PS3) Console
We transferred to a new home and a new dsl account. I've reset my netgear wgr614v5 to its default settings and reconfigured it to access but now it only works for pc's that are wired into the ports....
When you reset the router the default setting for encryption is probably off. Hopefully you had encryption on in the old home - but now the wireless computers are still trying to connect using the key/encryption.
Feb 05, 2010 | NetGear WGR614 Wireless Router
Connect Sprint PCS Sierra Wireless Aircard 402 home network??
Yes, you need to get in the router settings and disable DHCP in LAN configuration. That should do it. Also enable the ICS for the Air card. (Right click on Sierra Wireless icon, properties, advanced, check the box next to Allow others networks user to connect through this computers internet connection)
Sep 24, 2009 | Cell Phones
Need to reset mcafee wireless home network
You have to delete the existing network and start the setting up of new network.
Jan 29, 2009 | Network Associates McAfee Wireless Home...
Klipsch G17 Air Wireless Airplay Speaker System Logo
118 people viewed this question
Top Klipsch Audio Players & Recorders Experts
rhodesworks
richie46
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
