Question about Saeco Royal Digital Plus Automatic Coffee Maker and Espresso Machine
Recharhe circuit recharge circuit
Braun 7series will not recharge yet will work because she still has power in it what can I do when the charge finishes
If it is not recharging, you have a problem with the cord or the charging system (circuit board). You will need to determine which.
If new cord is needed, you will find at shaveroutlet.com.
You will need to know your specific model number is circuit board is needed.
Braun Replacement Charging Cord for Pulsonic and Series 7 Models and More
Jan 02, 2017 | Braun Health & Beauty
I'm one of many who have had problems with the battery exhausted signal one gets with Nikon cameras, even sometimes with freshly charged batteries.
Yes. It sure could have caused the problem. You didn't say which Nikon camera you have, so consider this a general answer. NMH (Nickel Metal Hydride) batteries are rechargeable and alkaline batteries are not. When your camera is set for rechargeable, the recharging circuit is activated when your camera is plugged into the wall outlet. When the camera is set to alkaline, the charging circuit is disabled. Therefore, if you had the camera set to alkaline and you used rechargeable batteries, you batteries were never getting charged. Since your NMH batteries were in a discharged state, your camera gave you correct information.
Jan 01, 2017 | Nikon Cameras
Why is my nikon coolpix L20 battery exhausted even with new batteries
If you are using rechargeable batteries, It could be that your camera's battery charger circuit is defective. If your camera is out of warranty, the cheap solution would be to buy an external charger. Another possibility is that a short circuit or defective electronic component is drawing excessive current and draining your batteries. If that is the case, you will need to have your camera repaired. Nikon USA Repair Depot's number is 1-800-645-6687 9AM-8PM EST, Monday to Friday. They will tell you how to return your camera for repair and they will give you a free estimate if it is out of warranty.
Sep 01, 2014 | Nikon COOLPIX L20 Digital Camera
Does the garmin need a ion battery to work?
jon battery is inside, may have flat charge, try recharge waiting more;
jon battery protection recharging circuit, may be broken or battery pack loose minimum voltage to be recharged, about 2,5 volts.
SAFETY recharge range of jon batt. is 2,8 to 4,15 volts.
Apr 23, 2014 | Garmin NUVI 360 GPS Receiver
Battery exhausted even after charging.
There are two possibilities. First, rechargeable batteries do not last forever. Take out your rechargeable batteries and replace them with non-rechargeable ones for test purposes. If your camera works ok, it may be that the camera's charger circuit has gone bad. Try charging your batteries on an external charger. If they charge, it is your camera's charger, if they do not hold a charge, it is probably time for new rechargeable batteries.
Sep 11, 2013 | Nikon Coolpix 3200 Digital Camera
Batteries will not recharge on stand. Have used different rechargeable batteries but same result
It could be the metal contacts that's used for recharging the mouse that isn't making a proper connection. The most common cause for this, would be dirt & oil that would build up on the charging contacts over time.
I would try to clean the contacts with a dry tissue paper on both the mouse and the charging stand and see if the mouse will charge properly again.
If that doesn't work, then maybe it's just the recharging circuit inside the mouse that's broken.
Jun 03, 2010 | Logitech Cordless Mouse
Honeywell CT200A thermostat battery will not recharge.
Yes the battery charge circuit is burned out, you might as well replace the thermostat, parts will not be made to fix it unless it is still under warranty.
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Saeco Royal Digital Plus Automatic Coffee Maker and Espresso Machine Logo
10 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
