Question about Grinders
Oven does not switch on
Does not switch on
The bottom oven light and heat is on all the time can shut off
Faulty switch if Oven light has a switch, some ovens light stays on, some oven lights switch.off when door closed. As to Oven being on all time , Faulty Switch.
Mar 13, 2015 | Ovens
My Neff oven is displaying the locked "key" symbol...does anyone know how to unlock please?
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
Mar 21, 2013 | Neff B1641 Single circotherm super...
We need to slam the oven door to switch off the intenal light and make the oven work?
cleaning your oven door switch might help but I would consider replacing the switch. The switches are sealed and cleaning does not work well.
http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Smeg F65 Stainless Steel Electric Single...
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Will not heat up
1. Make sure the controls are set properly,that the oven selector switch is set correctly and that the temperature
switch is set to the desired temperature where applicable,make sure the oven timer is set to manual.
2. If nothing else on the Range,Oven or Cooktop is working then
1. Check the circuit breaker or fuse.
2. Test for power.
3. Test the oven elements.
4. Test the oven thermostat.
5. Test the oven selector switch.
Feb 03, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Oven will not heatup
  1. Make sure the controls are set properly: that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
  2. If nothing else on the Range, Oven or Cooktop is working then Check the fuse
or
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
Jan 18, 2010 | Ovens
Faulty programmer - oven switches itself off
Try powering everything off at the main switch, waiting a few mins, switching back on and set the clock. Make sure the oven clock is in manual mode and switch the oven on and see what happens.Let mw know.
Jan 01, 2010 | Stoves 720EF Electric Double Oven
Oven blows main switch
There is a short circuit between the lower oven control and the lower element.
Disconnect the lower element. Put electrical tape on the loose terminals and turn the lower oven on.
If it does not blow, replace the lower element with a new element.
If it does blow, Check the wiring to the lower element for continuity to the frame of the range.
If you get continuity replace the damaged wire..
Finally, check the control knob switch for continuity to ground on the frame of the oven.
Mar 20, 2009 | Ovens
Dacor Wall Oven won't heat - Cannot find thermal reset switch
Open the oven door and unscrew the vented panel at the top. Make sure the oven is off. Atop the electronics in there you'll see a little red button. Push it. Voila.
Dec 24, 2008 | Dacor MCS130 Millennia Electric Single...
OVEN SPARK IGNITOR
bad ignitor switch on oven control , switch is behind knob and panel, disassemble and replace switch.
Feb 19, 2008 | Whirlpool SB160PEE Gas Single Oven
Grinders Logo
104 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
