Question about Taylor 9857 Electronic Digital Bathroom Scale
Changing Battery Error
I got a low battery reading so I changed the 9 V battery and I continue to get a low battery reading. I have tried several new batteries but the message continues to show batt and it won't show weight anymore.
r321567499
  • 74 Answers
SOURCE: ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
  • 10 Answers
SOURCE: I got a low battery message. I eplace the old
go and get new batterys
Posted on Jul 13, 2009
  • 10865 Answers
SOURCE: When I weighed myself 4 times in a row today it
hello. Definitely change the battery. Also make sure the scale is on a hard surface, not carpet.
please rate my answer as helpful. thank you.
Posted on Feb 23, 2010
rockmeister
  • 2047 Answers
SOURCE: Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Posted on Sep 02, 2010
SOURCE: I have a Taylor Led scale #9876B ...I purchased
I have the 9876 also. After 2-3 yrs it quit. W/ new battery it does the walking o's, then ERR1. I opened it and found that it uses a strain gauge, read by an MCU. The wires leading to the strain gauge were crushed between the top of the gauge and the plastic top cover. If I wiggle the wires I get a reading , but inaccurate. Then when they lose connection, there's no reading. Considering the slop in the metal links to the strain gauge, I don't consider it repairable.
Posted on Sep 30, 2012
I have a 2004 F150 airbag flashing 1 3 so a code 13 can not find any shorts to ground
Possible airbag computer when an airbag is deployed you must replace airbag module with airbag and seatbelt if locked.
Aug 17, 2016 | Cars & Trucks
My SB 700 shows temperature after few shuts and when it's twisted
From the SB 700 manual page b8:
v Notes on continuous fl ash photography • To prevent the SB-700 from overheating, allow it to cool down for at least 10 minutes after 15 times of continuous firing. • When continuous flash firing is repeated in quick succession, the internal safety function adjusts the recycling time by up to 15 seconds. If flash firing continues, the thermal cut-out indicator appears on the LCD and all operations are suspended. (0E-31) Allow it to cool down for several minutes to disable this function. • The conditions under which the internal safety function is activated differ depending on the temperature and the SB-700 flash output level. Operation B B-8 Slide the battery chamber cover open while pressing the battery chamber cover lock release. Insert the batteries following the [+] and [-] marks. Close the battery chamber cover. STEP 1 Inserting the batteries Operation B B-9 1.5 V alkaline AA battery 1.5 V lithium AA battery Rechargeable 1.2 V NiMH AA battery Suitable batteries When replacing batteries, use four fresh AA-type batteries of the same brand from any of the following types: • For minimum recycling time and number of flashes for each battery type, refer to "Specifications." (0H-27) • Alkaline battery performance may vary greatly depending on the manufacturer. • 1.5 V carbon-zinc AA batteries are not recommended. v Additional precautions regarding batteries • Read and follow battery warnings and cautions (0A-19 - A-22). • Be sure to read and follow the warnings for the battery on the section, "Notes on Batteries" (0H-9), before using the battery. • The recycling time can be longer when lithium AA batteries are used because they incorporate a function that suppresses the output current when heat is generated in the batteries.
Nov 26, 2015 | Cameras
Battery is new, has been charged and checked several times, it has a intermentant draw. i pull #2 maxi fuse and draw goes away. ive pulled all small fuses with no result
Check your ground (the negative cable on the battery). See if you have continuity between engine and battery negative terminal (-).
Dec 11, 2010 | 2004 Saab 9-3
My canon a75 continually says low battery after changing them
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jul 16, 2009 | Canon PowerShot A75 Digital Camera
New batteries but shows the batteries are low
what kind of batteries are you using? They recommend alkaline try reading this it talks about hte batteries
http://www.vtechkids.com/_f/_pw/_manual/80-077300%20Kidizoom%20Camera.pdf
Jul 07, 2009 | Vtech Kidizoom Digital Camera
Car doesn't start
Hello;
I believe you have a drain on your battery. Sometimes it can be very aggravating to locate. Easiest way I know to figure it out is to first get a digital ampmeter that reads low amperage. Take off the positive cable and attach the ampmeter in line. You will probably see an amperage reading. Go to your interior fuse panel and one at a time pull a fuse. Look at the amp meter and continue to pull and reinstall a fuse until the reading changes. Once the reading changes you can read what circuit you have disabled. Then you can start your trace from there. I have seen glove box lights and trunk lights that stay on and will run a battery down in a couple of days.
Hope this helps;
Rich
RPM Northwest
Jan 27, 2009 | 2001 Chevrolet Impala
Outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
Nov 19, 2008 | SkyScan 86742 Digital Atomic Wall Clock
LX7 Mouse False Low Battery Reading
I have found that sometime these Rodents seem to have a "Taste" for a certain "Type" of AA or AAA cell, one needs to get the Highest Discharge rate one can get. Often the "Brand" of Batts supplied are the "Only" ones that seem to work 100% alla time? I have had similar problems with customers B4, and I find the Varta series of battery to be great. & remember just because you bought them "New" don't mean the Batts are always "Fresh", get batts from a place that has a high turnover.
Aug 10, 2007 | Logitech LX7 Cordless Optical Mouse
Taylor 9857 Electronic Digital Bathroom Scale Logo
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
