Question about Polaroid PTAB750 7" Android 4.0 Childrens Tablet; 1GHz Processor, 512MB RAM, 8GB Internal Storage, SD Card Slot, 800x480 Resolution, 2.0 Megapixel Back Camera, Dr. Seuss & Smithsonian Interactive Books, Game Arcade with 16 Games, Kid-Safe Video Player, Side a
Tablet will not charge
No charge not charger
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Trouble charging a Digland 10.1" tablet
Did the charger that you are using come with the Tablets? Many 5 volt chargers can only output a 0.5 to 1amp current, while a Tablet typically needs 2 to 2.5 amps charging current. So, if you're using a charger from some other device, then it's almost certain that it cannot provide a sufficient current for the Tablet, and the charger overloads, shuts down cools off, turns on again, overloads again, shuts down etc repeatedly - giving the exact symptom you are reporting.
Even if the charger did come with the Tablet, some of the Chinese ones are of very poor quality and cannot provide reliable service. A replacement charger rated to suit your Tablet (there should be something in the specifications that came with the Tablet listing the requirements for the charger) should solve your problem {:o)
Jan 01, 2015 | Tablets & eReaders
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
Tablet charger is 400mAh and Tablet battery is 4000mAh. is my charger sufficient ?
The charger is right for the battery. IF battery won't charge on it proper charger, the battery or charger is bad. Take it back or put out more $$$$$$$$$.
Aug 31, 2014 | Tablets & eReaders
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
Visual Land Prestige won't charge
take the tablet to a store that sells charger , ask if you can test it before you buy it
Nov 22, 2013 | Visual Land Connect 7" Tablet
Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Nov 09, 2013 | Tablets & eReaders
Nabi will not charge .have new charger
Whenever you plug in your Nabi 2 tablet to charge, The tablet will boot up. Whenever tablet boots up, turn it off and leave it charging for a good 4 to 6 hours. That should charge it.
Aug 12, 2013 | Nabi 2
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
Polaroid PTAB750 7" Android 4.0 Childrens Tablet; 1GHz Processor, 512MB RAM, 8GB Internal Storage, SD Card Slot, 800x480 Resolution, 2.0 Megapixel Back Camera, Dr. Seuss & Smithsonian Interactive Books, Game Arcade with 16 Games, Kid-Safe Video Player, Side a Logo
41 people viewed this question
Top Polaroid Tablets & eReaders Experts
John mullen
nexrad_chris
WTF Chuck.....
WTF Chuck.....
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
