Question about Ski-Doo 2005 GSX Fan 380F
Fuel spraying out top of fuel pump
Fuel spraying out of whole on top of fuel pump
    Champion:
    New Friend:
  • 220 Answers
It needs to be rebuilt.
Posted on Oct 20, 2014
1998 Audi A4 starter spray
no
you fix the reason why the injectors are not working
could be fuel pump , pressure regulator , injectors , wiring or ECM
have the fault codes read
Dec 28, 2017 | Audi Cars & Trucks
How do I get fuel from fuel pump to carb on a 1994 Isuzu pickup truck after I install a new few pump?
The fuel pump is electric? It should feed the carb with a few pushes on the accelerator peddle with the key on. If not, try "starting fluid" available at local auto parts store. Comes in a spray can and you spray it into the top of the carb while someone else turns the key and pumps the gas peddle.
Apr 26, 2016 | Isuzu Cars & Trucks
It won't start
Check the fuel pressure by spraying starting fluid into the air intake of the engine, if it starts and dies then you need a new fuel pump most likely. The fuel pump is located inside the fuel tank. Make sure you don't have a Security light on in the dash as that is a whole different issue and also causes the fuel pump not to run and hence no fuel pressure, that is a theft lock our.
Apr 27, 2012 | 2001 Buick Century
It stalled on me now it wont start i checked and there is still a spark going to the spark plugs. I also to the carbarator top off and everything looks good its still spinning it is not loose. I sprayed...
try taking of the air intake and spray carb cleaner into it and then try to start.
if it tries to start and then dies then your having a fuel issue.
that may be the fuel pump.
remove the back seat, put the key in the second position right before turning it over and listen for the fuel pump to start up.
if you dont hear anything then your fuel pump is bad or not getting power.
and then i would check the fuel pump relay switch first before replacing the pump.
hope this helps
Aug 06, 2011 | 1998 Honda Accord
It is full of kerosene however when I plug it in to start, it will not turn on. It makes the effort for about two or three seconds then turns off
The safety is turning it off because it is not lighting. You did not mention if it was actually trying to light, or if it was just the motor running. If it is not lighting, take the top cover off and watch the ignitor. Depending on the type of ignitor, it will either glow or spark when you plug the heater in. This should happen before the fan starts running. Once the fan starts, you should be able to see a mist of fuel coming out of the nozzle. If there is no fuel spray you may have an air pump problem, which is on the back of the motor, or the fuel screen in the tank may be plugged.
1. Check for ignition source
2. Blower motor should start, if you have ignition
3. Fuel should spray out of nozzle, if not check filter and check for air flow out of the pump.
4. If you do not have any air flow, or not enough air flow check the pump. Pressure out is critical.
5. If pressure is too low check for leaks around the pump. Spray soapy water on the back side of the motor/pump housing. The plastic pump cover is bad about cracking, and the cracks are very hard to see. The plastic cover could also be loose on the pump.
6. While on this end of the pump; the filters need to be clean, as they will affect the pump pressure and upset the whole apple cart.
Jan 18, 2011 | Reddy Heater-30-55,000 BTU Variable
Cant get fuel lines off the fuel pump from factory pump
that is a tough one ... get some penatrating oil with a catylist accellerator mixed in and spray all fittings. let stand overnight. they should break loose the next day
Feb 07, 2010 | 2000 Chevrolet Blazer
I PUT A NEW FUEL PUMP ON A 2000 BRAVADA AND IT FIXED THE PROBLEM FOR A FEW DAYS.WHILE GOING DOWN THE ROAD THE ENGINE DIES.WHEN YOU TURN THE KEY YOU CAN HEAR THE PUMP RUNNING FOR AWHILE.HAS SPARK.WILL RUN...
Check all the fuel lines and connections very carefully for leaks and condition. The pump may be drawing some air.
We assume you have the correct fuel pump for the vehicle, that it is operating normally, you have the correct fuel filter and that there are no obstructions in the fuel system as a result of the work carried out so far.
Dec 04, 2009 | 1993 Oldsmobile Bravada
Du1145xtpq top spray, and upper spray arm don't
sounds like the chopper is plugged or broken. remove the lower spray arm by holding tab with a set of plyers and turn spray arm counter clockwise. then where the middle spray arm attaches at the back of tub remove screw. turn the housing on pump to the right side of the machine( its easier to pull top rack out a bit so that whole housing can move) it will turn a little bit to be released from top of pump. then take out the torx screws that hold the housing and filter on. in the sump there will be one or two more smaller torx screws remove those and remove coverings to the chopper. check to see if the mesh is plugged with food and other things. clean. also check to see if blade turn with the motor impeller. if not then the chopper needs to be replaced. good luck
Dec 03, 2009 | Whirlpool Dishwashers
How to remove fuel pump 1995 camaro z28 5.7
If you have a Fuel pump blown and needs replacing you probably have been quoted approx $220 for the pump and about $450 labour and about 6 hours of work.
Due to its location you would have been informed that suspension, exhaust, support bars etc have to be removed before the tank is removed then the pump removed right?
Here's what I did, I removed the back carpet, I then drew a cut out area central on the flat of the highest point on the body pannel and cut a wide hole, leaving one section attached for folding back down later. My position was perfect, I unscrewed the pump and replaced it with the new unit.
I cut the plate with a drill to start, then I used tin snips to complete the cuts. {NO GRINDER or OXY}
I folded down the flap and sealed it, I then got 2 galv plates from home depot {$0.80 each} and screwed it over the top, then sealed the edge and sprayed it with a can of black paint. Looks like a factory access area.
Took me 55 minutes all up, and saved me $450. I have pics available
Nov 29, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Ski-Doo 2005 GSX Fan 380F Logo
273 people viewed this question
Top Ski-Doo Winter Sports Experts
ptpumpman
David Harrelson
David Harrelson
Noel Bennett
Level 1 Expert
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
