Question about Ubi Soft Entertainment The Settlers: Heritage Of Kings (Gold Edition) for Windows
Settlers 5 rw engibe set video mode
Why Settlers - Rise of an Emmpire + Lenovo Z510 + NVidia GT740 did not started
Why Settlers - Rise of an Emmpire + Lenovo Z510 + NVidia GT740 did not started? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
200 001 170DTLA AH Proview 860 AB0 170DTLAQH Power Supply Backlight...
May 18, 2014 | Ubi Soft Entertainment The Settlers: Rise...
Tip
Porteus on a MultiBoot USB Flash (Grub4DOS)
Porteus is a linux distribution customized for USB flash
and disks (live mode)
It is available as 64bit and 32bit solution
to install on USB flash, CD, MP3 player, camera and hard drive.
Porteus 32bit
1.) Download the Porteus 32bit ISO image:
http://porteus.org/index.php#
2.) Create a folder porteus on a USB flash drive.
3.) Take from the downloaded ISO, files
vmlinuz
initrd.lz (from the folder boot)
and all content (from the folder porteus)
will be placed in a folder porteus.
(extract the files from the ISO can programs Ultra-ISO or WinRar)
4.) In the main menu.lst add a:
title Porteus ==>
configfile (hd0,0)/boot/menus/porteus.lst
5.) In the folder /Boot/menus/ (Create a folder on a USB flash drive)
to file porteus.lst (Create a file on a USB flash drive) add:
splashimage (hd0,0)/BOOT/Splash/slacktux.xpm.gz
foreground 000000
background ffffff
timeout 30
default 0
title Porteus Graphics mode (KDE)
find --set-root /grldr
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;telinit~4 fromusb
initrd /porteus/initrd.lz
title Porteus Graphics mode (KDE),Copy To RAM
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=xconf;telinit~4 fromusb
title Porteus Graphics mode (LXDE)
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=lxde;xconf;telinit~4 fromusb
title Porteus Graphics mode (LXDE),Copy To RAM
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw copy2ram autoexec=lxde;xconf;telinit~4 fromusb
title Porteus Graphics mode (KDE) + Save changes /porteus/
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=xconf;telinit~4 changes=/porteus/ fromusb
title Porteus Graphics VESA mode
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw autoexec=telinit~4 fromusb
title Porteus Text mode
kernel /porteus/vmlinuz max_loop=255 ramdisk_size=6666 root=/dev/ram0 rw fromusb
title Return Back <==
configfile (hd0,0)/menu.lst
title Reboot
reboot
title ShutDown
halt
5.) Download file
http://dl.dropbox.com/u/4040651/slacktux.xpm.gz
Put the file in a folder /Boot/Splash/ (Create a folder on a USB flash drive)
6.) Porteus on our MultibootUSB flash-is ready for operation.
INFO: MultiBoot USB Flash - Survival Guide (Grub4DOS)
http://www.fixya.com/support/r8170992-multiboot_usb_flash_survival_guide
on Feb 07, 2011 | Computers & Internet
Settler Rise of an empire on Windows 8
Settler Rise of an empire on Windows 8? This trouble maybe power supply or inverter boards is defective.
Jun 12, 2013 | Ubi Soft Entertainment The Settlers: Rise...
(CRX230ED) CD-RW Burner will it burn dvds?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Interface
ATAPI/EIDE
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-R, CD-RW,
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Multi-Session,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
Dec 03, 2011 | Sony (CRX230ED) CD-RW Burner
It is sony dcr-dvd105. i shot 5 minutes. if i finalize the 5 minutes, i basically lose the rest of the dvd, am i right? is there a way only finalize the 5 minute and transfer to pc and still be able to use...
I'm glad to inform you that it is possible to record additional scenes after finalizing when you use DVD -RW and DVD +RW discs.
When using finalized DVD -RW(VR mode) disc, you can record additional material on the disc without any additional steps.
Other case, you can unfinalize the discs using [UNFINALIZE] option under DISC SET Menu.
Please let me know if you require any clarifications.
Thanks for understanding.
Mar 15, 2011 | Cameras
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Ubi Soft Entertainment The Settlers: Heritage Of Kings (Gold Edition) for Windows Logo
91 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
