Question about Chevrolet 1988 Chevrolet S10/s15/sonoma Radio
The injectors wont fire on my 1998 chevy s10 zr2
    Problem Solver:
  • 15 Answers
Did you crack the supply to the injection pump to see if you had fuel pressure if you don't have your pressure then go back to see if you have a electrical supply to the fuel pump are these new injectors may need to bleed them..
Posted on Mar 30, 2014
Will a 1997 Chevy Silverado 1500 steering column interchange with a 2001 Chevy s10 zr2?
No, you have completely different specs on those. Wheel base, length and torque. Might get it to fit but it wont be right. Also there is a lot more than meets the eye with electrical connections on these.
Jun 10, 2017 | Cars & Trucks
Is it happening on all cylinders? Or just one? Have you removed the injector an inspected it. I have never heard of all going bad at once. It would be a good idea to look for open fuses. The main connector is connected properly, each one has good connection.have you changed something lately?
Mar 30, 2014 | Ipcw Chevrolet S10 / S-pu 1998 1999 2000...
Where is the security brain located on my 1998 chevy s10 zr2
if you are having problems that involve having to put fuel in (carb) and then the engine starts and run's fine then there is a problem with the either the starter settings in the ecu or you have a temp/maf sensor fault. if engine runs its not the immobilizer the immobilizer this would not let you start engine in any way cut power to the fuel pump and injectors and ecu start. try using a code reader on the engine and see if any codes are stured.
2002 chevy s10 turns over but will not fire after changing clutch
I can't imagine what could cause the engine not to start by just pulling the transmission out.
Are you getting spark to the plugs and fuel to the injectors ?
Fuel pump is running when you turn the key switch on ?
Feb 09, 2013 | 1998 Chevrolet S-10 Pickup
What is size of hub axle nut on 2002 chevy s10?
2002 chevy S10 ZR2
36 mm.
Torque 103ft pounds.
Mar 16, 2010 | 2000 Chevrolet Blazer
Need firing sequence and diagrahm chevy s10 v6
I take it the dist was removed, if not then your problem is probably not ignition timing
Oct 10, 2009 | 1996 Chevrolet Blazer
Chevrolet 1988 Chevrolet S10/s15/sonoma Radio Logo
94 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
CrisO
Lawrence Oravetz
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
