Question about Samsung WEP200 Headset
Wep200 i can hear people talk but they cant hear me all they hear is static
How can i hear what they are saying without that awful loud sound when they arent saying anything. cause when i turn the volume down i cant hear what they are saying
Turn up your SQUELCH button when no one is talking until the static noise just goes away.
Now your set will remain quiet until someone talks.
If you set the squelch too high it will also cut out the people talking, so always try to have it set just slightly above the background static level.
Good luck.
Apr 15, 2011 | Uniden BC350C Base Scanner
Cb puts out good sound but when someone try to talk to me it all you hear is static
same thing sometimes happens to me. Usually it is because the person who is talking to you might have a weaker antenna. Sometimes people put a very strong transmitter with them and talk to people but you cant talk back.
So really they can't hear you good either. Just because you are too far away.
Jan 11, 2011 | Cobra 29 LTD CB Radio
ICAN HEAR EVERYBODY BUT I CANT GET OUT I SWITCHED MIKS AND STILL CANT GET OUT people can hear me but when they talk to me all i hear is static
You said that you can hear everybody and then you said all you can hear is static. Which is it?
If you can hear everybody and you have switched to a known good mike, then you either have a bad antenna or you have a bad final amplifier caused by a bad antenna or by having transmitted at sometime without an antenna at all.
May 27, 2009 | Cobra 29 LTD CB Radio
Cannot connect my wep200
Hold the front button on the WEP200 for about 15-20 seconds, the blue light will be steady and your phone will be able to pair and connect with the headset, passcode is 0000
Nov 17, 2008 | Samsung WEP200 Headset
No voice
I have the same problem. I bought it from amazon.com a few months ago and had to send the first one back because of the same issue. However, this one did not present the problem until it was past the return window for amazon.com. :-(
Jul 02, 2008 | Eforcity Samsung Bluetooth Headset WEP200...
Can not hear voice
did you just purchase the unit? if so it may be defective. As far as i can tell this headset should work with the handset you specified and i cant find anything saying there is something special you need to do. Most i can say if you can return it or get it replaced its probably your best bet. Sorry I am unable to provide you with a more positive easier solution. But I hope this puts you on the right track. Thank you, Nathan
Jun 16, 2008 | Samsung WEP200 Headset
Music from blackberry 8820 to Samsung WEP200 bluetooth headset.
cheak headphones maby went out output settings in the samungs cheak vol up
Jan 27, 2008 | Samsung WEP200 Headset
Samsung WEP200 Headset Logo
Top Samsung Radio Communications Experts
JP Services
JP Services
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
