Question about LG GE Computers & Internet
Install LG GE24NU40 on Mac will not detect drive
Burner will not mount
I want to add a DVD player/burner to my Gateway 3250S (Gateway Pentium 4 2.66 GHz). Can anyone please help me know where to find one that should just slip into the CD-CDRW slot?..Thank you
Being realistic you are going to pay through the nose for a compact drive for a PC that is coming to the end of it's useful life (sorry but it's true). A better investment would be to purchase an external USB drive from dabs or ebuyer at least then you can keep the drive when you change PC and even use it between different pc's
Jul 05, 2011 | Computers & Internet
HI - i get an error code 0x80020020 from my external bluray burner now - using my Mac - model LG WH10LS30K
Probably the driver don't compatible with Mac but for windows, search another driver for Mac
Feb 02, 2011 | LG WH10LS30K BLACK SATA LIGHTSCRIBE 10X...
Installer Drive LG GP08NU20 for Mac
Do people read before they write, this thread is about an LG and mac, so saying support is provided in windows is somewhat dumb and unhelpful
Oct 07, 2010 | LG GP08NU20 DVD±RW Burner
I bought an LG external DVD burner model GE20LU10 yesterday. It says on the box that it would work on Mac. Nothing inside on the manual or CD says anything about it working on a Mac. I've called...
install an LG burner on a MAC
if the burner shows as connected or mounted on your screen you just have to install or use your burning utility i.e. nero, sonic, or whatever you have installed on your mac.
when you open the program and have your files already processed and ready to burn, it will ask you what unit you want to use for the task, open the menu and select your burner, click next or continue, the encoding will start, when it finishes the encoding the burner will start.
if you are using a USB connection it should work with your software
Apr 27, 2010 | LG GE20LU10 AUAE10B DVD±RW Burner
How to install lg super multi drive gp08 premium on a mac
Hi, how I instal lg super multi drive gp08 premium on laptop
Mar 03, 2010 | LG GP08NU20 DVD±RW Burner
Just got an lg ge20 not working on mac
I wish I could tell you that your Mac is compatible with the LG GE20 20X DVD Burner but unfortunately it is not.
Here are the system requirements for this burner
LG GE20 20X DVD Burner Technical Specifications
The CD included is not the only item that is not compatible with the Mac, it is also the DVD burner itself. It is only windows compatible I'm afraid.
However, I do know that the Apple.com online store, has a comparable DVD+RW burner, the
LaCie 22x d2 DVD+RW with LightScribe
which will work with your iMac.
This is a genuine incompatibility issue.
If you had an Intel iMac, there actually is a workaround process where virtual machine software, like VMWare Fusion or Parallels, could be installed, with a version of Windows XP, Vista, or 7, display as a 2nd terminal within a Mac OS X desktop.
What's makes this effective, is that the LG GE20 could work with a windows virtual machine and because software like VMWare for example, can share devices, including optical CD/DVD drives, the Mac could share that drive with the windows virtual machine.
But since you do not have an Intel iMac, unless I am reading the description of your Mac computer(Apple iMAC Mac Notebook) incorrectly, the LaCie burner information, I provided above, would be the best option for your model of iMac.
Again, if I have described your model of Mac incorrectly let me know and I will be glad to assist further.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iMac Notebook
I've just bought one of these for a Mac G4 running
You need to locate a piece of software called Patchburn - but I think that might be difficult now.
This particular vintage mac only worked with the drive that was in it. in order to use a different drive you had to patch the system so that the new drive would be recognised as a burner - that said, it should just work as a player/CD-ROM.
The later Macs didn't have this problem and you could stick a drive in and it would be recognised straight away as a burner. I recently put a LG drive (with lightscribe) into a G5 mac and it worked straight away as a burner/player but I did have to install the lightscribe software.
Oct 13, 2009 | LG SecurDisc 20x External Double-Layer DVD...
I downloaded free light scribe software but it
I recommend you use Lightscribe system software
use this link I have provided to download and install Lightscribe softwares.
http://lightscribe.com/DownloadSection/mac/index.aspx
Good Luck.
May 14, 2009 | Computers & Internet
Cant instal as have no installaltion cd
i have to down load pictures from lg 195 set through computer whcih driver i have to intall
Aug 20, 2008 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Lacie external dvd burner not detected
DO YOU HAVE THE DRIVERS FOR THE BURNER CORECTLY INSTALLED ?
TRY IT ON A DIFFERENT COMPUTER TO SEE IF IT WORKS.
IF IT DOESNT YOU MIGHT NEED TO CHANGE EIGHTER THE DRIVE OR THE BURNER
Dec 30, 2007 | LaCie d2 DVD-RW Burner
Computers & Internet Logo
53 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
