Question about Cuisinart Digital Thermometer Meat Fork
Code hh will not show temperature
Batteries are ok
Indoor panel is a code 7202 rev HH showing?
need more info is it a wired controller if so make sure 4 pin red plug is plugged into bezel board sometimes they unplug for winterization if plugged in make sure where it goes into house or into RS system that the wire isnot cut or nicked sounds like it isnt seeing controller if all ok shut system down and reboot
Apr 07, 2014 | Jandy AquaLink RS OneTouch RS16 Pool or...
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
I ge a 6521 Rev HH Error on my Jandy RSA All Button Controler
check 4 pin connectors to see if wires touching if ok check cable probably cut
Jun 28, 2012 | Jandy 6886 AquaLink All Button Indoor...
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
My LG 2.5" external HH
Windows Me and newer do have the needed driver build-in.
You do not need any 3th party driver.
1. Let Windows search for the device in the Device Manager.
2. Try another cable
3. Try another port
4. Try also on another PC to check if the device is OK.
Sep 13, 2011 | LG 320GB USB 2.0 Portable Harddrive - Red...
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
What does hh.h mean on display
I'm assuming it just stands for "High Humidity". It wasn't raining at the time, but it sure had been earlier, so perhaps if it's over some number (like 90%), it just says "HH".
Nov 01, 2010 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
Hi,I need a replacement battery pack for my Sitex handheld VHF HH-250.Thanks Original 8N-600
What you need is at the VERY least is a Ni-Cd battery pack with 600mA/hr rating. We have an HH-300, with a configuration of 4AAx2.
Interstate Batteries has the BEST price I could find, although when we bought the HH-300, I sent it to SiTex for a new battery AND a tune-up which cost around $100.
Here's the link to the Interstate battery website.
<a href="http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-NIC0068(Other+Products).aspx?dsNavigation=Ntk%7eSearchGroup%7cSitex+HH%2f-250%7c3%7c%2cNy%7eTrue%2cNtpc%7eDisabled%2cNs%7eproduct+Type%7c101%7c1%7c&Title=9.6V+800mAh+NiCd">http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-NIC0068(Other+Products).aspx?dsNavigation=Ntk%7eSearchGroup%7cSitex+HH%2f-250%7c3%7c%2cNy%7eTrue%2cNtpc%7eDisabled%2cNs%7eproduct+Type%7c101%7c1%7c&Title=9.6V+800mAh+NiCd</a>
Hope this helps.
(EDIT)
Do NOT forget that these radios are wired center pin negative! (Don't ask how I found this out...)
Sep 22, 2009 | SITEX Boating
Cuisinart Digital Thermometer Meat Fork Logo
Top Cuisinart Home Experts
Donni Steen
Tom Chichester
Are you a Cuisinart Home Expert? Answer questions, earn points and help others
