Question about Parker House Portofino Space Saver Entertainment Center
How to connect lights?
Don't know how or what to plug lights into to get them to work
Wireless light flashes & can't connect
Are You Sure You Have Signal coming into modem/router sometimes the red light indicates no connection is it dsl or cable or? if DSL can you use the phone disconnect the filter. and plug the cord strait into the wall plug.cable could be the connection check for shorts could be an issue with your carrier call them for a simple electronic reset Hope this helps!
Jul 26, 2017 | Belkin Components F6D4230-4 Wireless...
Ford f 250
take the plugs and swap them u have the running light plug which are hazards and probly blinkers too. then u have ur tail lights and ur brake lights twwo plugs swap them sounds like ur not geting a got connEction
May 25, 2013 | Cars & Trucks
My two idiotlights don't come on when you turn key on and head lights don't work. have replaced ing. switch with no change
check for a fuse near the engine to tractor wiring connector. check battery cables for looseness & corrosion. tighten the ground cable where it connects to the chassis and inspect the engine to chassis bolts. loose connections can cause backfeed problems, such as when you step on the brake pedal in your car, and can then turn on the radio...
Dec 16, 2012 | Garden
I have an acer wireless mouse model mg-0766 and i cant get it to connect to my hp pavilion laptop. the batteries are fine. the dongle light doesnt come on but when i plug it in it does download the dr
Hi friend , make sure you have install the proper driver of it, if you don't have the driver or you don't know what is the exact driver, then my suggestion is you can install windows 7 operating system then i am sure it will work, or you can check it out by connecting a different computer where windows 7 is installed. make sure the usb port is working fine also.
Sep 25, 2012 | HP Computers & Internet
Onn wrieless mouse is not working
Try replacing the batteries in the mouse. Sometimes the light will still come out of the bottom of the mouse - but the wireless signal is no good.
Also - after you replace the batteries in the mouse, click the sync button on the USB part that plugs into your computer, and then immediatly click the sync button on the bottom of the mouse.
That should do it!
Nov 14, 2011 | Computers & Internet
2007 fatboy lost the 'flashing' of turn signals (but they still light up), lost horn, lost rear break light. All fuses in the fusebox are OK. I also lost all gauges (speedo, neutral indicator,...
Your turn signals (but not your running lights), horn and a few other things are on the "accessories" fuse in your electrical circuit, I think. If the fuse is not blown, I would guess that you have a bad connection in the power lead for that circuit. I'm not sure of what I'm going to say here because I don't work on the newer bikes but in the older bikes, the "orange" colored wires carried the battery voltage to the individual components much like "red" wires used to do in most DC circuits. I'd look for a bad connection in a plug somewhere. I hope this helps but like I said, I don't know a lot about the newer bikes. I mostly work on the older bikes that the dealers will not work on any longer.
Good Luck
Steve
Aug 13, 2011 | Harley Davidson FLSTF Fat boy Motorcycles
I just bought this TV - LG -32LD350, and I plugged it in, and no lights came on, no screen, no sounds, nothing. I don't know what is wrong with it, I tried unplugging it then plugging it back in after...
Plug it then use tester to check the wire that connects from the transformer to the panel, if there is no current then The power transformer is bad, replace it and every thing will work fine.
Aug 09, 2011 | Televison & Video
Were are the main wires to wire up a towbar are they behind the rear side panels or under rear bumper and where is the best site to get a light diagram thank you
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done
May 21, 2011 | 2000 Suzuki Grand Vitara
Parker House Portofino Space Saver Entertainment Center Logo
65 people viewed this question
Top Parker House Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Parker House Furniture Expert? Answer questions, earn points and help others
