Question about Zippy EL-620 Keyboard
Right shift key doesn't work
Right shift key no longer makes capital letters
Left shift key types symbols not capital letters
it could be set to do so in system settings, like a shortcut. or there could internally be something inside under the keys which causes it to do that
Nov 03, 2013 | Computers & Internet
Tip
Blackberry Tips
<br /> <img src="gfxcasa_0.jpg" /> <br /> <ul> <li>To move the cursor in a different direction, hold down the<i> Alt key</i> and roll the trackwheel.</li> <li>For a letter, hold the letter key until the capitalized letter appears.</li> <li>To go to a screen, press the Space key. To move a screen, press <i>Shift + Space key</i>.</li> <li>To move to the next item, press N. To go to the previous item, <i>press P</i>.</li> <li>In the<i> calendar</i>, to change the calendar view, press A. To switch to day mode, <i>press D</i>. To change to Week view, press W. To change to Month view, <i>press M</i>.</li> <li>Making use of the letter, hold the letter key until the capitalized letter appears.</li></ul>
on Dec 06, 2010 | Cell Phones
Capitol letters to begin each word
Try following :-
  1. Select the text that you want to change the case of.
  2. On the Home tab, in the Font group, click Change Case za010210667.gif (as shown in the diagram below), and then click the capitalization option that you want.
    • To capitalize the first letter of a sentence and leave all other letters as lowercase, click Sentence case.
    • To exclude capital letters from your text, click lowercase.
    • To capitalize all of the letters, click UPPERCASE.
    • To capitalize the first letter of each word and leave the other letters lowercase, click Capitalize Each Word.
    • To shift between two case views (for example, to shift between Capitalize Each Word and the opposite, cAPITALIZEeACHwORD), click tOGGLE cASE.
    • To apply the small capital (Small Caps) letter formatting to your text, see the note and diagram below.
Jul 07, 2013 | Computers & Internet
Shift key
You may have to buy a USB or wireless keyboard and bypass the laptops.
Jul 22, 2012 | Toshiba Satellite M35X-S163 Notebook
Why my email cannot open. Invalid ID or password.
Make sure that your using a "Shift" key/selection before capital letters in your login name or password; if there are any capital letters.
If both login name, and password only contain lower case text, make sure "Shift" isn't being used and that their isn't a "CAPS LOCK" engaged.
Aug 24, 2011 | Yahoo YHT-630 System
I am trying to do a cap and can't figure out how to to change frame setting to be able to do this
Are you talking about making text capitalized?
If so, then all you need to do is hold down your "shift" key on the bottom left of your keyboard at the same time you press the letter in which you want to make capital and then release both keys.
If you want to type a whole line of capitalized letters, press the "cap lock" key on the bottom left side of your keyboard and then you dont have to hold down the shift key.
Mar 06, 2011 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
How to type in capital letters on facit typewriter?
You did not specify if it was a manual or electric or the model, so assuming it is a standard manual or electric machine, push down on the shift key and hold it, then type your letter or letters. If you are typing everything in caps, press the shift lock key.
Aug 20, 2009 | Office Equipment & Supplies
Capital letters
You can either turn on CAPS Lock or hold the shift key while typing. Have you already tried this?
Jan 30, 2008 | NorStar Refurbished OTM 1.x Billing...
How do you make you r letters capitol on sign in page for email
You can make the letters capital just by pressing "0" key
"0" key here works as a SHIFT key of computer
You will notice that when you press this key, there is a
change in upper right corner, for example look like this:
"abc" All small letter
"Abc" First capital and others small
"ABC" All small letter
Jan 14, 2008 | Cell Phones
Zippy EL-620 Keyboard Logo
Top Zippy Computers & Internet Experts
gbob59
 Mikey
Mikey
Ed Watson
Level 1 Expert
Are you a Zippy Computer and Internet Expert? Answer questions, earn points and help others
