Question about Falcon MSNR Mighty Sonic Safety Horn Refill Can FALMSNR FAL MSNR
Falcon g2865 cuts out
Falcon fryer cuts out
How to fix LD 48 falcon fryer
safety thermostat tripping by pass and test,then replace if it is the problem, it must be in place for safe operation??
Jan 18, 2016 | Kitchen Appliances - Others
WHEN FRYER HEATS UP THEN IS LOADED TEMP SEEMS TO FALL AND HAS TO BE RESET
If you manually reset by pressing overtemp thermostat, then check your operating thermostat.. maybe over heating.. if so replace thermostat.. if pilot cuts out completely prematurely without reaching set temp then replace overtemp cut out thermostat as it is faulty.
Cheers
Mar 22, 2012 | Pitco Frialator SG14 Deep Fryer
Commercial deep fryer keeps getting to hot, having to reset, is it possible to replace thermostat ??
Hi there.
Your fryer may have problem in cutting off the heating element power (electric fryer) or burner flame (gas fryer) for temperature regulation which is thermostat's main function.Thermostat is replaceable, you have to identify the manufacturer of your fryer to get the exact component.
Regards.
Aug 24, 2011 | Kitchen Appliances - Others
I have a pitco 12 fryer properly converted to run propane just bought, saw it working am now staring it up for the first time. i see the pilot and how to light it. i have two concerns. first some of the...
If the wires on hi limit were cut and shorted, it is possible that the hi limit is bad and needs to be replaced as soon as possible because it is the safety device of the fryer.
Hi limit is designed to cut burner flame in case oil temp reached 450F to avoid further damage on life and property.
Washers need to be tightened/ replaced to correct burner alignment. It is not safe to operate a fryer with misaligned burners.
Nov 04, 2010 | Pitco Frialator SG14 Deep Fryer
Hi. I bought an AMT Millenium Falcon model kit
Hi Robert, I think I can help. I recently found this site with a lot of information about star wars model kit.
Go to this link about the AMT Millenium Falcon Cut-away version
http://www.starwarsmodels.com/mfca.html
There is a download link to the right which contains the original instructions. Even if you don't have the cut-away version I'm sure this will help!
Jim
Nov 29, 2009 | Toys
Ihave a commercial falcon double well gass fryer need servcing
You can go to the website of the manufacture and find a local dealer, or you can call any appliance repair shop and ask for the nearest restaurant supply and warehouse in your area, most appliance repair shops could service it.
Aug 28, 2009 | Kitchen Appliances - Others
Fryer promblems
This is caused by a failing coil on the gas valve. You should replace the gas valve.
May 08, 2008 | DCS FSF-40 Deep Fryer
Falcon MSNR Mighty Sonic Safety Horn Refill Can FALMSNR FAL MSNR Logo
Top Falcon Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Falcon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
