Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD533HD5 repair, blown STK's or bad power assy?
Hope someone here can help us out... Our 7 year old SD533HD5 finally bit the dust a couple of weeks ago. It has been a fantastic tv and we really would love to keep it in the family.
Anyway....over the last couple of years it has exhibited the dreaded 'not coming out of standby' problem, easily fixed by replacing the 4A 125V fuse in the power board. This would usually happen after a power outage or if somebody switched on the TV within 5 mins of switching it off.
The most recent time this happened however the fuse fix did not work and it would repeatedly blow the replacement with the 'def assy' fault led lit on the power board.
So I read up on here and other places that the most likely cause was the convergence amps. So I ordered 2 stk392-180's from ACME plus a replacement for a diode that had discolored the PCB right next to the blown fuse.
I replaced the chips and diode, checked my work for spills/bridges and loose connectors and put it all back together.
After powering up the tv stayed on green for several seconds longer than before then reverted to standby. I switched the power on and the fuse promptly blew. I replaced the fuse and tried again...this time we got picture but the convergence is shot....especially blue...also no sound on any input.
hmmm....faulty convergence IC's? or did they just blow again as something in the possibly faulty power supply shoots too much current?
Funnily enough we never had any convergence issues with the tv before it died.
Any ideas guys? thanx : )
  • Pioneer Master
  • 5,138 Answers
Go back recheck everything 6amp fuse in middle of power supply board that will blow, also solder everything that looks like poor connection pioneer always has a lot of cold solder jionts.CK all pico fuses they are green,yellow look like resistors but are fuses.
Posted on Jun 15, 2009
Trying to locate what board has the convergence ics for a Pioneer Pro700HD.
It is likely on the video board.
At today's price point, it is often less expensive to replace with a more modern television that can be hung on the wall, and does not take up so much valuable floor space.
Good luck with your repair.
Feb 11, 2018 | Pioneer Televison & Video
Pioneer plasma tv turns off every 15 minutes and has to be restarted and go off in 15 mins.
Sounds like it may be overheating. Make sure all the vents are clean and clear and the inside electronics are not covered in dust etc.
Feb 09, 2015 | Pioneer PureVision PDP-4340HD 43 in....
While watching TV (all audio ran through my Pioneer VSX-516), the receiver shut off by itself, so I powered it back on. Then it powered off again a couple mins later, and wont power up at all now. I...
Try holding the "advanced surround" and "enter" buttons and see if it turns back on. If it shuts off again, disconnect all speaker wires and try it again. If it stays on, you have a bad speaker or wire. If it still shuts down, the amp is blown and needs to be repaired.
Mar 29, 2013 | Pioneer VSX-516-K
I have two 7 month old Pro Com vent free gas garage heater ( Model Number MD300 TGA Propanr heaters. I use them for emergency heat during power outages in my greenhouses. Last year they worked perfectly...
Are all three now connected to the same source? That might have something to do with it. Anyway a safe and easy solution is to flush the pilot assembly with Rustbuster and allow it to dry . This clears the pilot of dust and cobwebs without disturbing the innards of the vent free safety pilot. Muck that uo and you will have to buy another. Get yourself some rust buster.
12_1_2011_9_38_55_pm.jpg It has a flexible tubing that fits right into the pilot.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 30, 2011 | Procom MN300HGB Heater
My toshiba cinema series hd rptv 2000 has started doing the 3d affect it is a old full screen that is 9 years old.
The convergence IC's are probably bad. That manufactured year set should use two STK-392-110's. Also be aware that the low ohm resistors near the heat sink could also be bad or stressed. They would be discolored if stressed or bad. If you are not savvy with removing and replacing electronic components do not attempt repair. Call a professional.
Hope this helps,
Skyassoc
Jun 27, 2009 | Hitachi 51F500 51" Rear Projection...
Power light goes on then shuts off after a couple seconds
my friend you have a power supply problem,check the fuses, replace any blown one and if blows the fuse again you need someone with electronics skills to replace one the yokes that is bad,usually is the red.
caypianan@yahoo.com
Jul 27, 2008 | Mitsubishi WT-46807 46" Rear Projection...
SD533HD5 Blowing Fuses
No lo creo ,ya que el problema puede ser el circuito horizontal checalo o manda la tv a un taller.
Mar 17, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer 610HD Rear Projection
Check all solder joints on the deflection board.
Dec 10, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
571 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
