Question about Philips Sc2003/11 Lumea Precision Plus Rechargeable Intense Pulsed Light Hair Removal System
Philips lumea its stopped working
Help I have lost my charger for Philips SC2006/11 Lumea charger, model NL9206AD-4, where can I buy another adapter?
Suggest that you try to reach Philips support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Apr 15, 2015 | Philips Televison & Video
Does the battery in the Philips Lumea Precision SC2002 IPL hair Remover need replacing? I've had it nearly two years and it will no longer charge. thanks
Here is a guide how to replace the faulty battery pack yourself. It's a known problem that the batteries are dead if you don't charge the Lumea for more than 3 months.
Replacing battery in Philips Lumea LazyAdmin
Mar 02, 2015 | Philips Health & Beauty
My remote has stopped working for my HTS3520 blu ray, how can I select language choice & start films without it?
If the remote really has stopped working, the practical solution is to obtain a replacement Philips remote that will control all player functions.
Feb 02, 2015 | Philips Televison & Video
The battery went bad in my gogear mp3
Talk to Philips about it at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Dec 18, 2014 | Philips GOGEAR Audio Players & Recorders
Lutron Dimmer: 'IN' does not always equal "ON"
These are probably three-way switches being used as two-way. If so, then the switches will have three terminals, but only use two. Just switch one of your wires to the other terminal. If the light will not light, that was the wrong wire. Don't mess with it without turning off the breaker! Good luck.
Feb 25, 2013 | Lutron LG-600P Lumea Single-pole 600 Watts...
Try to add a dimmer but we have 2 blacks and 1 red wire. Product has 2 black and 1 green. How to connect?
Usually this is indicative that you have a 3-way lighting circuit, but only a single-pole dimmer. For most lighting circuits, the red wire and one of the black wires are supposed to be run over to a second light switch. You need dimmer rated as a "3-way" in order for that to work. If you get stuck, I would call the manufacturer's tech support number at 1-800-523-9466. They're available 24/7 and it will not cost you anything.
Jul 23, 2011 | Lutron LG-600P Lumea Single-pole 600 Watts...
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
Mar 03, 2011 | Philips Lightolier Onset 600W Incandescent...
I have a philips trimmer it was working properly but suddenly it stop working as i have using that so kindly tell me what to do and where is the service centre of philips
U didnt mention the location of your living... kindly visit your nearest philips center and ask them to replace your trimmer with a new one.
May 20, 2010 | Health & Beauty
My Philips remote stopped working. 42PF7421d/37
my philips tv remote stopped working after i tuned a simple remote to it! so now my origenal remote will not worl model no. 26pfl5522d/05
Dec 31, 2009 | Philips Televison & Video
My philips GOGEAR SA6045 MP3 Player won't turn on
Runa Repair in the Philips Device Manager - make sure the lock switch is not engaged.
Jul 17, 2008 | Philips SA3125\02 MP3 Player
Philips Sc2003/11 Lumea Precision Plus Rechargeable Intense Pulsed Light Hair Removal System Logo
105 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
