Question about Philips MWD2205 DVD Player/VCR
Unclear, Zig-Zaggy, Snowy Recorded Pictures Through Converter Box
I have a Magnavox analog TV (about 12 years old) and a Magnavox MWD2205 DVD player with VCR player/recorder that have worked well together until the DTV transition. I do not have cable or satellite service. I have no problem with receiving the digital channels. I actually receive more now with the converter box (Magnavox TB100MW9). The problem I have is with getting a clear picture for programs I have recorded. The recording works fine except the picture. It's in black and white and is zig-zaggy and snowy. I know that I won’t have a digitally clear recorded picture image, I just would like a color (analog-type) picture image. I have the following hook-up sequence: Antenna out to Converter Box in, Converter Box out to VCR in, VCR out to TV in. It was suggested that I try: Antenna out to VCR in, VCR out to Converter Box in, Converter Box out to TV in. I tried this, but I only received one channel, so I switched it back. Is there a solution to make the recorded images (analog-type) clear? Will the images vary from channel to channel? Thanks!
  • clarklori40 Jun 16, 2009
    I'm a little confused. I have the antenna going to the converter box and the converter box going to the vcr and then the vcr going to the tv, so the converter box is going into the vcr - is this what you mean?
    President:
  • 1,996 Answers
Have you tried turning off the power to the digital converter when you wqnt to watch the analog VCR programs? Some converter boxes (most I would think) have analog pass-through functionality, which allows viewers to see channels that continue as analog even after the change. (rural areas). By turning off the power to the converter box, the analog signal should just pass through without interference.
Posted on Jun 16, 2009
  • efs_perpends
    efs_perpends Jun 16, 2009
    If you have a VCR connected to the TV to record TV programs, you must set the channel on the converter box to the TV channel you want to record.
    If you have programmed recordings set up, you must set the channel on the converter box to the TV channel for the programmed recording before the start of each recording session.
    To connect a video device:
    1. Disconnect the coaxial cable that goes from the antenna connection to the video device, if connected
    2. Connect the coaxial cable from the antenna connection to the From Antennae jack on the back of your converter box.
    3. Connect the supplied audio cable to the R aAudio and L Audio jacks on the back of your converter box, connect the supplied video cable to the VIDEO jck on the back of your converter box, then connect the other ends of the cables to the corresponding jacks on the back of the video device.
    4. Depending on the type of AV jacks on the video device and the TV, connect the Audio and Video OUT jacks on the video device to teh Audio and Vidoe IN jacks on the TV.
    5. Plug the power cord into a power outlet or surge protector. The light on the box turns red.
    6. Turn on the TV and set the TV to the appropriate video source. (For more info, see the TV;s documentation.) (Using a universal remote, press the TV/Video or AV button and scroll through the options until the VCR picture is clear.
  • efs_perpends
    You have an option to check the signal strength with most converter remote controls. How is the strenght of the signal on the station you're trying to record? Make sure you have a good connection between the converter box and the input on the VCR.
    If you can, use video cables to make the link between the vcr and tv, instead of coaxial cable.
    Sergeant:
  • 326 Answers
Definately the images will vary from channel to channel. the channel transmitting quality i request to use converter.
My Magnavox Converter Box is TB110MW9 and we have problems making the volume louder. I looked at the hand book and it was telling me to go to RF OUt but that never worked. If we play the DVD player on...
You are confused about the purpose of your Magnavox STB. It converts digital frequencies to analog for your analog TV to process. The left and right audio outputs connect to corresponding inputs on the rear of your TV (the same ones used by your DVD player) for amplification. There is no volume adjustment on the STB.
Jan 27, 2018 | Televison & Video
I have a magnavox converter box for our TV to convert Analog to digital - how do I hook up a DVD player thru it?
you cannot use the dvd player of the combo through one of these converters
however for the vcr portion here are a few easy steps
connect the magnavox converter to the IN on the back of the VCR
then tune the vcr to channel 3 or 4 whichever the converter is set to
Dec 04, 2010 | Philips Magnavox DVD/VCR Dual Player
When I record a movie on the vcr it plays back snowy.
Ur VCR signal recorded free air throught an DTV converter box?Yes,this cause is normal,because VCR player have no digital tuner on the VCR player by itself,on it circuitries design.If recorded throught pay cable signal.Yes,than ur VCR video head player is dirty needed to be clean.Tries websites like Amazon.com,Ebay.com to buy a VCR video head cleaner vdeo tape.Just play it as normal as a video tape,when the video head clean,VCR will display clean head eject tape now.
Aug 03, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
Can't get any channels!
Most likely you have a problem with signal strength. Unlike the old analog broadcasts, where a weak signal just made the picture fuzzy, a weak signal on the digital channels isn't even detected. You will need a better antenna. Depending on how far you live from the stations, and what kinds of obstructions (buildings, hills, and such) are in the way, you might need to put up an outdoor antenna. But try an amplified indoor antenna first. You may find that's all you need.
If this has helped you, please take a moment to rate the solution. Thanks for asking here!
Feb 18, 2009 | Philips MWD2205 DVD Player/VCR
I pluged this in & it wil not show up on my tv
You cannot use RF (channel 3 or 4) to see the output of the Magnavox. You need a RF modulator or separate video/S-video and audio inputs. The antenna signal is passed through the 2160 for analog signals.(and digital if you have a converter box or digital tuner)
tom
Jan 21, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Philips MWD2205 DVD Player/VCR Logo
131 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
