Question about KitchenAid KGRT607 Gas Kitchen Range
F2e3 Oven turns on but shuts off before getting to tempeture
I change thermostat, water pump, housing coolant sensor, but yet when i start driving the tempeture goes up and down and the heat gets kind of cool not all
poor coolant flow water pump? air lock in system? bring to operating temp shut down than open air bleed screws.
Jan 02, 2014 | 1997 Pontiac Sunfire
Oven preheats but will not maintain heat
Hi you have a bad thermostat for the oven , I would guess that everything else is working ok on this unit correct ? if you send information i will look up the part for you this is easy to replace , as always turn the power off before service or unplug
Nov 25, 2011 | Maytag Ovens
Oven does not maintain tempeture
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 19, 2011 | Kenmore Ovens
My Whirlpool gold double oven displays the code F2E3 on the electric panel This problem occurs when I attempt to set the oven to bake. It is now a permanent display
F2 E3: Key held down too long or key is shorted.
Check keypad connector for firm connection. Press Cancel, if error returns after 60s replace keypad.
Jun 28, 2010 | Whirlpool GBD307PD Electric Double Oven
F2E3 WILL NOT TURN ON
this sometimes works; remove power from the range unplug etc. then: get some 90% isopropyl (rubbing) alcohol from the drug store put a sprayer on the bottle and saturate all the controls and wires etc. that got wet then wait overnight or. untill all surfaces are dry and, plug in your range; your range should work again
Apr 21, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
OVEN TEMPERATURE TOO HOY
if its maxed you cant just turn it down accordinly to what they tempeture is to cook if its 350dgs use 300 dgs
Feb 22, 2009 | GE JGBS23 Gas Kitchen Range
Oven not heating
there is more to this than meets the eye if youre oven takes a long time on fan setting it may be thermostat but more likely to be fan not turning at all or quickly enough the stat capillary is above oven element and if fan not blowing air away from capillary oven stat will shut oven temp down too soon if using conventional heat eg no fan make sure there are no full size trays directly on bottom of oven this will block heat from bottom element effectively giving only half the heat output.
hope this helps
Jun 13, 2007 | Bosch HBN 430560B / 430520B Single Oven
KitchenAid KGRT607 Gas Kitchen Range Logo
24 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
