Question about LG Tromm Electric Dryer
Clothes aren't getting dry
My LG Tromm dryer is not getting my clothes dry. It's getting warm but doesn't seem to be getting as hot as usual. What could be causing this?
    Master:
  • LG Master
  • 676 Answers
Check your vent hose and where it exits the building, clean away all lint anything blocking the vent cap or in the vent hose. Remove the vent from the back of the dryer and make sure it is all clean and clear there and make sure the betn is not kinked up when putting the dryer back into it space. Now before you blow me off, if any of this is true for your dryer the heat will build up and trip the thermostat causing it not to heat properly and the blower wheel can not move the air to collect the moisture and remove it from inside the dryer. Also, any sagging vent line can collect moisture which turns to a puddle of water in the line and this to will not allow your dryer to dry the clothes. Good luck I hope I have helped you.
Posted on Mar 30, 2014
  • 4 Answers
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Posted on Feb 23, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
SOURCE: my lg tromm dryer is not drying clothes. it takes
your heating element is going out
Posted on Jan 30, 2010
SOURCE: LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Posted on Feb 01, 2010
CMV9
  • 594 Answers
SOURCE: LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Posted on Apr 13, 2010
LG Tromm DLE 7177 WM not drying clothes. vent is clear and unobstructed, the heating element upper right is hot to the touch, and it seems there is a reasonable amount of air venting to the outside.
There is a upper limit and lower limit thermostat I believe, YouTube repair clinic channel has all the test info and parts.
https://www.youtube.com/user/RepairClinic
Apr 25, 2017 | LG Dryers
Hi. My LG Tromm Dryer DLG3788 warms at times, heats hot others and sometimes won't heat at all. Either way the clothes either don't dry at all or take hours. Any suggestions? Thanks.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Dryers
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
I have a LG TROMM DLG5988S, it doesn't warm up my clothes
your element is defective or a thermal fuse is open, possibly the hi-limit switch is defective
Oct 18, 2009 | LG DLG5988 Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Lg tromm front load dryer dlg5988w
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm Washer
Embarrassing as it was, the hot/cold water hoses were switched - although it was installed by HomeDepot that way. It just didn't seem consistent enough for it to be such an easy solution...but it did the trick!
Dec 20, 2007 | LG WM2688HWM TROMM SteamWasher
LG Tromm dryer now takes two cycles to dry a load
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
Dec 20, 2007 | Dryers
LG Tromm Electric Dryer Logo
83 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
