NEC Electra Elite DTU 16D-2 Corded Phone Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not reset the display to change the Name displayed when I call someone.
Brian LaDuca
Level 2:
  • Expert 149 Answers
  • Posted on Jun 15, 2009
 Brian LaDuca
Expert
Level 2:
Answers
149
Questions
0
Helped
146636
Points
228
You need to access program mode and change mb 4-10 to the correct name.
How do you change the display names on the Avaya 5420.
hi robert.
see if this helps you,if not go to the link and the bottom.
How to change the display name in Avaya phone? Press the Select soft key or the OK button or the right arrow key. Use the up and down arrow keys to scroll the display to the option Display Name. Press the Change soft key to change the setting or use the left or right arrow keys. Display your extension number and the date and time on the phone when it is idle.
Display Name - Avaya
marketingtools.avaya.com/knowledgebase/user/ipoffice/.../1408/display_name.htm Search for: How to change the display name in Avaya phone?
How do you change the display names on the Avaya 5420 Google Search
2answers
Hi I have a Nec DT300 at work. I am on a new desk. Do you know how I can change the name which is on the display.
If you have the Admin password then follow this procedure:
For a DT330 (24-Button with 4 line LCD)
Do not lift the handset and press the Speaker button
Enter #*#*
Enter the 4 digit admin password and press the Transfer button
The phone will now display 'Program Mode'
Select Base from the four options using the associated softkey
Enter 15 and press the select softkey 2 times
The Extension Number and Ext Name will be displayed
Find the Extension Number you want to change the Extension Name for using the + and - softkeys
Press the Mic button to go to the Ext Name line
Enter the New Name using the number dial keypad.
If you make an error the Recall button will delete a character to the left and the Hold button will delete all characters to the right of the cursor.
Press the Transfer button to accept the new name.
Press the Answer button 4 times or until 'Program Mode' is displayed.
Press the Speaker button.
The system will save the changes and return the display to normal.
How do I change the display name on KX-T7630
http://service.us.panasonic.com/OPERMANPDF/KXT7630.PDF
4helpful
I need to know how to change the name that shows up with each extension and how to access the voicemail if you do not have the previous users password?
I'm guessing that your looking to change the name on the telephone system and not the voice mail.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
The password on the mailbox that you don't know the password to will need to be reset to access that mailbox. While in admin programming you can change the name on the mailbox.
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
If you pres the next soft key 2 or 3 more times you'll come to the name of the mailbox press Chng and enter in the new name (the # key advances by a space and pressing # twice puts the comma to separate the first and last name press ok when finished
press the Rls key
your password will be reset to 0000
9helpful
6answers
I need to change our Auto Attendant message to remove the name of an employee that is no longer with us. I have tried Feature 983 but when I enter the recommended 120000 (we have 2 digit mailboxes) it says...
The best thing to do at this point is to reset the admin. password.
To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
To reset your voice mail password, press feature 983 the screen should say log:
enter 120000 (default password)
press ok
press the Rls key
your password should be reset to 0000
I need to change the ip address of my sharp ARM276 network printer and I don't know the user name and password. I need to reset the username and password to their defaults to login. Can someone help with...
You can't reset password, but you can see admin PIN on printer's display.
Just use simulation 22-7.
You can read about simulations in "service manual".
Voice mail display & retreving messages
Do you know how to get into phone system programming? The extension names are changed in there.
Panasonic KX-T7668 Change name displayed on extension??
This facility of changing name is in admin program. when you call up some body their name will bw displayed on your screen. It's fine .tell us that what name other person get.
Display name when you check voicemail- T7280model
i think i can talk u through this, call me if u want
gary
309-346-5582
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
