Question about Video Game Consoles & Games
How to adjust thr front Front windows
1967 ford mustang convertible with 289 ci v-8 engine
SOURCE: 1967 ford mustang 289, 4bbl
hesitating when from a standing start, then running well can be caused by having too big a jet size. I dropped the size of the jets on my Holley 4V, and it solved that part of the problem. The accelerator pump will push in too much gas, momentarily "drowning"the engine til you get enuff air to mix with the gas.
Posted on Apr 21, 2009
Pops65Pony
  • 137 Answers
SOURCE: 1965 Ford Mustang 289 overheats at highway speed
A partially blocked radiator will also cause htis symptom. Had this happen on two cars in the past. Take radiator to shop for rodding out and cleaning.
Posted on Apr 22, 2009
  • 41 Answers
SOURCE: how to install front windshield trims on a 1967
There should be several clipps around the glass. It has been a few years since I did my 67. You should be able to press down and wiggle the trim till it pops onto the clipps. The trim has a small groved edge on the back that the clipps grab onto. Then you slide the other trim parts together and press and wiggle them onto the clipps. Hope that helps.
Posted on Aug 04, 2009
SOURCE: I have a 2004 Ford Mustang convertible. My back
Mine was doing the same. I used 3M double sided tape and it worked perfectly.
Posted on Aug 10, 2009
jturcotte
  • 7789 Answers
SOURCE: need to know how to adjust valves on a ford 289
I assume you have hydraulic lifters. If not, please get back to me. We used to do this with the covers off and the engine running, but that was messy. Here is procedure from autozone.com:
This procedure for the 289 and early 302 V8 engines is designed for engines in which the rocker arm mounting studs do not incorporate a positive stop shoulder on the mounting stud. These engines were originally equipped with this kind of stud. However, due to production differences, it is possible some 289 or early 302 engines may be encountered that are equipped with positive stop rocker arm mounting studs. Before following this procedure, verify that the rocker arm mounting studs do not incorporate a positive stop shoulder. On studs without a positive stop, the shank portion of the stud that is exposed just above the cylinder head is the same diameter as the threaded portion, at the top of the stud is of greater diameter than the threaded portion, this identifies it as a positive stop rocker arm stud and the procedure for the 351 engine should be followed.
  1. Crank the engine until No. 1 cylinder is at TDC of the compression stroke and the timing pointer is aligned with the mark on the crankshaft damper.
  2. Scribe a mark on the damper at this point.
  3. Scribe three more marks on the damper, dividing the damper into quarters (see illustration).
  4. With mark A aligned with the timing pointer, adjust the valves on No. 1 cylinder by backing off the adjusting nut until the pushrod has free-play in it. Then, tighten the nut until there is no free-play in the rocker arm. This can be determined by turning the pushrod while tightening the nut; when the pushrod can no longer be turned, all clearance has been removed. After the clearance has been removed, tighten the nut an additional 1 / 4 of a turn.
  5. Repeat this procedure for each valve, turning the crankshaft 1 / 4 turn to the next mark each time and following the engine firing order of 1-5-4-2-6-3-7-8.
Posted on Oct 25, 2010
The firing order for a 289 cu 1967 ford mustang
go google and type in-- firing order of ford engines---
it shows the firing order and the distributor rotation for each engine
Dec 28, 2016 | Ford Mustang Cars & Trucks
I have a 1965 mercury comet with a 289 v8. I want to know what type of differential I have in it so I can buy a new cover for it
Here are the spec's for the 1965 mercury comet, 289 V8:
For 1965, the Comet Cyclone was powered by the 289-cu.in. V-8 with 225hp, the same engine that was put into Mustangs. And for more power, there was a special high-performance package, better known as "Hi-Po," available with the Cyclone, and it shared the 271hp V-8 which, when installed in a Mustang, was known as the "K" code car. In the Comet, the engine code is "A." When equipped with the Hi-Po package, a 1965 Cyclone came standard with: 289 four-barrel high-performance engine, four-speed Toploader transmission, nine-inch differential, performance suspension, quick-ratio steering and 8,000-rpm Rotunda tachometer. However, the following items were extra-cost mandatory options with the 271hp engine package: four-speed transmission, heavy-duty front suspension, low-profile rayon tires and 42-amp alternator, according to 1965 sales information.
Its a 9-inch differential at best. Try this link for more data:
1965 Mercury Comet Cyclone
Apr 13, 2015 | Mercury Cars & Trucks
I have a 67 mustang w/8 cyl, 289, I need firing order diagram?
FIRING ORDER
1967 Ford Mustang 4.7L 2BL OHV 8cyl
The Firing Order
Select the part number to view the diagram.Firing order 1-5-4-2-6-3-7-8 ----------front ' 1 2 3 4 ' of ' ' distributorrotates counter vehicle ' 5 6 7 8 ' clockwise---------
Sep 08, 2014 | Ford Mustang Cars & Trucks
I NEED TO KNOW WHERE THE ENGINE IS ON A 1967 MUSTANG 289 V8
it is in the front of one of the heads or on the block i think it is the left side just above the oil pan or it is on the back of the heads
Jul 04, 2013 | 1998 Ford Mustang
I need feeler gauge settings for tappet adjustment on a 1967 ford mustang 4.9 engine please
Found this online:
Engine
  • Measure the camshaft lobe lift with Ford Tool Numbers 4201-C, 6565 and 6565-AB. Use Ford Tool Number 4201-C to measure crankshaft end play. Check valve clearance with Ford Tool Number 6513-K unless the engine is a 390 or a 428, in which case Ford Tool Number T58P-6565-A must be used. If the engine is equipped with rocker arm studs, remove the studs with Ford Tool Number T62F-6A527-B. Install the studs with Ford Tool Number T62F-6A527-A4. Remove the harmonic balancer with Ford Tool Numbers T58P-6316-A and T62F-6316-B. Install the harmonic balancer with Ford Tool Number T52L-6306-AEE. Replace the crankshaft front oil seal with Ford Tool Number T58P-6700-B. Remove the camshaft bearings with Ford Tool Number T58L-101-A. Install the camshaft bearings with Ford Tool Number T53L-200-A.
  • Read more: Classic Mustang Restoration Tools ' eHow.com http://www.ehow.com/list_6908584_classic-mustang-restoration-tools.html#ixzz1B8AZ6fjK
    Jan 15, 2011 | Computers & Internet
    What is the spark plug firing order for a 1989 Ford Bronco with a 302 Cu. In. V8 engine?
    There are three kinds of 302s made from 1982-2001. 5.0L HO This engine was used in 1983-1995 Mustangs, Mark VII Lincolns, and some T-birds and Cougars. All Explorer 5.0L engines are 5.0L HO engines as well. They use the 351W firing order, 1-3-7-2-6-5-4-8. Except for the 1983-84 Mustangs, all of these engines are roller cam equipped. They use a reverse rotation water pump and front cover. The 1994-5 Mustang and all Explorers use a unique front cover and water pump. 5.0L Full Size Car This engine was used in 1982-1990 Crown Victoria and Grand Marquis. They use the 289-302 firing order, 1-5-4-2-6-3-7-8. Most of these cars are not roller cam equipped, however sometime in the early 1990s they started using roller cams but retained the 302 firing order. They use a standard (clockwise) rotation water pump and front cover. 5.0L Truck (except Explorer) These engines are similar to the Full Size Car engines, except they use different intake manifolds and camshaft profiles. They also use the 289-302 firing order, 1-5-4-2-6-3-7-8. They also began using roller cams sometime in the early 1990s. They use a reverse rotation water pump and front cover.
    Good Luck
    Nov 12, 2010 | 1989 Ford Bronco
    Have 67 Ford Mustang GTA 289V8. How do spark plug no. layout on engine left side is 1-3-5-7 and right side of engine is 2-4-6-8. Would that be correct and what is firing order?
    The 67 289. Right (passenger) side, 1-2-3-4, left (drivers) side 5-6-7-8. Firing order, 1-5-4-2-6-3-7-8 cc. This should also be cast into the intake manifold in front of carb. Also, dist rotation is counter clockwise as your looking at motor from front, and #1 should be at approx 1 Oclock position. Most dist caps will have it marked.
    Oct 20, 2010 | Ford Mustang Cars & Trucks
    What are the timing settings on a 1967 mustang 289 motor
    Hello! Here is a link to a specification sheet for your vehicle...<br /><br /><br />http://www.carmemories.com/cgi-bin/viewexperience.cgi?experience_id=131<br /><br />Guru......Saailer<br /><br />
    Aug 28, 2010 | 1966 Ford Mustang
    Firing order
    1-5-4-2-6-3-7-8
    May 05, 2010 | 1966 Ford Mustang
    Ford mustang 1966 convertable
    What the heck is "rego"? Please translate from UK slang to American English please.
    Standard HP is 210
    289 cubic inches = 4735 cc
    Charlie
    Jun 23, 2008 | 1966 Ford Mustang
    Video Game Consoles & Games Logo
    66 people viewed this question
    Top Video Game Consoles & Games Experts
    Josh Whitehead
    Josh Whitehead
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
