Question about Hoover Soft Light Supreme U4262-930 Bagged Upright Vacuum
Where is the reset button?
Reset button
Will not turn on...is there a reset button?
Most higher quality vacuums have a reset button but many do not. You did not state what vacuum you have so I can't say for sure.
May 28, 2016 | Vacuums
Where is the thermal reset button
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you epwill hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced.
Apr 10, 2016 | Riccar 2000 4000 series Upright High...
How do I fix the brush bar reset button on Dyson DC24?
Hi there, it's Jack at Dyson.
The reset button will not remain depressed after it's been pushed. Instead, you should hear and feel a click when pressed - it can help to use something like the eraser-end of a pencil. The steps are shown in our video guide below:
If you've been unable to reset the cleaner head after pressing the reset button as shown, or if you're worried the reset button isn't working correctly, please get in touch as we should be able to help you further.
You can reach the Dyson Customer Helpline directly by calling us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Please have your DC24 to hand when you call so we can take you through some troubleshooting checks.
Aug 15, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Where is the reset button on a DC24 ball?
In most cases, DC24's reset button should be located in a red recess on the side of the cleaner head, as shown in the video guide below. It may help to use something like the eraser-end of a pencil to press the button - you should feel a click as it engages.
Some newer DC24 variants don't include a physical reset button, and instead the reset mechanism will activate when you turn off the vacuum, then turn it back on and recline it into the normal vacuuming position.
If you can't see a reset button on either side of the cleaner head, this may be the case with your machine. If you're unable to reset the cleaner head, please contact our experts directly. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 14, 2015 | Dyson DC24 All Floors Upright Cleaner...
Does the Dyson 04 absolute have a reset button?
In the manual is no mention of any reset button. What could it be you want to reset? If there is a defect, there is no such thing as a button that can undo that. Reset is used on computer (computerised systems) to reload a program from scratch. Even on a computer with a hardware error, a reset can't help. Here is the Dyson manual:
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc04_uk_manual_sal_120710%20pdf.pdf
Dec 20, 2014 | Dyson Vacuums
Does it have a reset button on it.
Had a d4 and I dont remember there being a reset button ally x
Jul 23, 2014 | Dyson Dc 41 Ball
Reset button on Rainbow vacuum
There is not a reset button on this model
Apr 01, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Reset button dyson dc24
http://www.youtube.com/watch?v=akGLQ7UbctY
Nov 20, 2013 | Dyson DC24 Animal Bagless Upright Vacuum
Where is the reset button on my electrolux guardian canister
There is a reset button on the power nozzle...not sure I heard of the vacuum canister has a reset button....hum.
Feb 15, 2013 | Electrolux Guardian Bagged Canister Vacuum
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Hoover Soft Light Supreme U4262-930 Bagged Upright Vacuum Logo
15 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
