Door wont stay open
Drivers door will not stay in the open position.
  • 33 Answers
SOURCE: 2004 CHEROKEE, WONT RECONIZE DRIVERS DOOR OPEN,
its the ground wire for the driver door, and posably an ornge one, in the black shielding to the door they rip all the time but yet for some reason jeep has yet to make a recall. any who you disconect the battery then pull the shielding back and patch the wires together.
Posted on Jan 14, 2009
SOURCE: Kitchenaid dishwasher door does not stay up in the open position.
On each side of the dishwasher, near the ground, is a nylon cord and pulley apparatus that keeps the door from flopping down when opened. It probably needs some adjustment of the tension on the cord.
Posted on Feb 14, 2009
  • 315 Answers
SOURCE: 95' Camry drivers door lock is Jammed. Door wont open at all.
You tell me. Is jammed?
Posted on Aug 02, 2009
SOURCE: 2006 325 i door locks not working driver door will
I had a very similar situation. Was very annoying not being able to unlock or lock doors from pannel control nor from remote.
Only driver door can be opened with manual key.
Solution: One of the 15 amp purple fuses was blown. Fuses are located inside glove compartment, the interior end has to be removed releasing the two locks.
Use a light and the red tool located on the panel to remove fuses.
Posted on Oct 18, 2010
Testimonial: "very helpful thanks doors work now! "
rickyrt441
  • 4399 Answers
SOURCE: the inside door handle of
Your wire is probably broke. You have a thin piece of metal that goes from the door handle to the key slot. When you open it, it releases. I would say that needs replaced. You will have to take off the inner panel to get to it. There is probable 4-5 screws you have to take out. After that, you might have to pull the plastic and some foam out in order to have access to your problem. Best of luck to you. Hope this helps.
Posted on Feb 06, 2011
Cannot open rear drivers side door from outside or inside. door panel is off, door is closed. child lock is on. tried pulling cable, wont move. tried lifting up the child lock with a thin blade
Sounds like the lock mechanism is stuck on the locked position. Since you didn't specify make and model this is a best guess. Make sure the lock is in the unlock position and try manipulating the rod connected to the outside handle (since child lock is on the inside handle won't work)
Oct 07, 2016 | Cars & Trucks
Why does the door open light stay on in my 1998 Windstar when no doors are open?
is the switch in the always on position ? did they stay on for 30 seconds or so after locking /unlocking vehicle prior to this ? so i'd check the the light switch function, if ok then there may be a timer relay for the light that has failed , most likely located in fusebox lower dash drivers side or behind the kick panel drivers side keep me posted if you wish
May 17, 2014 | 1998 Ford Windstar
Door lock
Pull the door latch towards the front of the dishwasher until it clicks in the open position.
Mar 30, 2014 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Drivers side door wont stay shut in my 97 jetta
lube the latch up...
go to the passengers side and examine the latch... you could use a screwdriver and OPEN the latch on the drivers' door by pulling the door handle and prying the latch to the open possition... and try to close it ... repeate.
Mar 27, 2013 | 1997 Volkswagen Jetta
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
Door dryer would stay shut Now it wont start
when door was open it got bent down,gently try to pull it up in the open position,try lock alignment, do it in steps, so you don't over do it and break something
Jan 31, 2010 | Dryers
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
Dec 14, 2008 | 2004 Jeep Grand Cherokee
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
