Question about Conair Infiniti Instant Heat Ceramic Hair Straightener - Silver
Wont get hot
It lights up but only gets worm
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
How can I replace thermal fuse on steamglide iron?
If you are comfortable with working on mains appliances then have a look at this forum post on how to replace the thermal fuse.
http://mendmy.com/answers.php?id=78119
Aug 17, 2014 | Russell Hobbs Irons
I have a bosch TDS25 steam generator iron and when I plug in and switch the iron on the green light light does not come on
if the iron is still getting hot and generating steam i would say the light has failed, however if nothing is happening you could change the fuse in the plug if you now how if not get some one who dose and if this dose not help then i think your iron has had it
Oct 01, 2011 | Bosch Irons
My Conair Proshine Straightner won't warm up, although the light is on. How do I fix this? ... hot plates not heating and the light says its warming up but the hot plates won't heat up
Most heated hair appliances are protected by a thermistor that will fail if overheated. These are small, about 1/2" long, cylindrical in shape with a pointy end and a wire coming from each end. When they go bad, they do not conduct electricity (zero ohms on a meter). There is a three digit number on the side that is the shutoff temperature. You can get these at Radio Shack.
Don't bypass this safety device.
Jan 07, 2011 | Conair Professional Ceramic Hair...
My Norelco steam iron 1513 B, lights up, but does not get hot.
It likely has a burned-out heating element. Probably time for a new iron.
Jul 26, 2009 | Irons
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Not getting hot
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Jan 10, 2008 | Irons
Conair Infiniti Instant Heat Ceramic Hair Straightener - Silver Logo
27 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
