Question about Panasonic Kx-tga750b Dect 6.0 Cordless Expansion Handset And Charger Pack
Panasonic base unit says no power
Base unit says no power
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Panasonic KX-TG2740
u have to try change battry its might be week so try it
Sep 08, 2008 | Panasonic KX-TG2740 Cordless Phone
Tip
Fixing the handset link to base unit of Panasonic KX-TG4500
After the base unit died I was able to restore power by switching out the power adapter of one of the handsets with the one on the base unit. However, when the power was restored to the base, none of the handsets that previously worked were getting a dial tone. I could only use the phone from the base unit. To fix the handsets I first reset the base unit by pressing the reset button with the tip of a pen on the bottom of the base phone then momentarily removed and reinstall the battery on each of the handsets to allow each to reset individually. In doing so, I got the dial tone back on all previously linked handsets without having to reregister them.
on Mar 23, 2010 | Lands Phones
Panasonic kx-tga101s AC power connector plug fits loosely in handset base hole and drops power frequently
try blue tack or you can bey a putty that setts solid in 10 mins from one of the pound shops
Apr 07, 2014 | Panasonic KX-TGA101S Cordless Handset
How to register a panasonic a kx-tga850e
Look on the base unit, not the charging cradle. The charging cradle merely plugs into a wall outlet for power. The base unit is the device that's hooked up to the phone line.
Aug 24, 2012 | Panasonic Lands Phones
Callers complain they can't hear us - on all four handsets.
All the handsets work through the base unit, so I'd suspect the trouble is there. For some reason it's not passing the sound on to the phone line. About all you can do is unplug the base unit power supply, let it sit for a minute or so, then reconnect the power. This will reset the base and may fix the problem. If it doesn't, then something has gone bad electronically in the base and you'll need to have it serviced. The owner's manual and Panasonic's website will have information on how to obtain service. Usually you need to mail the unit to them for repair or replacement as they don't make service information available.
Mar 01, 2011 | Panasonic KX TG6441 Phone
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Panasonic Kx-tga750b Dect 6.0 Cordless Expansion Handset And Charger Pack Logo
19 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
