Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Call factory code F-28-3
On my Konica 7030 I'm getting "call factory" code F-28-3 when I try to copy.
Then the copy sheet gets stuck down on the right side in slot 3 I think it is.
Please advise if you have any idea.
Many thanks
  • Konica Minolta Expert
  • 158 Answers
Ts corona is shorted could be either the corona wire is broken or the terminal is arcing
Posted on Oct 24, 2009
Error F-35-9 code
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 03, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
A konica 7030 displaying a meassage " remove paper from the exit tray" on the screen, how do i fix it? tnx
check if there is a paper at your exit feeder try. at the fuser.
if not. see if the paper sensors are not stuck.
Nov 15, 2011 | Office Equipment & Supplies
F-28-3 knoica error
F 28-03 The toner separation ON/OFF operation has been performed 5 consecutive times since the separation trouble detection signal was detected at start of toner separation.Please check the HV2 unit,the transfer/separation corona unit.If there is a paper in copiymg proces when this jam occurs the machine stops after completion of copied paper ejectiom.
Oct 01, 2009 | Konica Minolta DiALTA Di200 Copier
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
679 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
