Question about Frigidaire FAFW3801LW Washer
No spin cycle
When I try to start it it just goes to the no spin cycle then shuts off
Washer completes cycle 100% but then it restarts and starts filling all over again/ rewashes in essence
Dear William, I guess first you have to check if the start switch is shorted. When you turn on the machine, does it automatically go into cycle? If yes, then your start switch is faulty. Otherwise, you may have to replace your timer/sequencer.
Jan 16, 2014 | Washing Machines
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
Washing machine does not drain
The load that you put in may be too big. Try taking some of it out and restarting the cycle. If the load is too big when it goes to start the spin cycle where it drains it just shuts it down.
Nov 11, 2010 | GE WBSR3140DW Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Kitchenaid washing machine not spinning
WHEN YOUR WASHING THE LID MUST BE SHUT BEFORE IT WILL GO INTO THE SPIN CYCLE. UNDER THE LID YOU WILL SEE A PROBE THE PUSHES THE SWITCH DOWN WHEN THE LID IS SHUT. THESE SWITCHES WEAR OUT , ONE THING TO TRY WHEN THE WASHER TRIES TO GO ONTO SPIN TAKE A NON MATALIC ITEM AND PUSH THE SWITCH DOWN AND SEE IF THE WASHER GOES INTO THE SPIN CYCLE, IF IT DOES THE SWITCH IS NOT BEING PUSHED DOWN FAR ENOUGH TO MAKE THE SWITCH WORK
THIS IS VERY COMMON ON ALL WASHERS
Aug 12, 2009 | KitchenAid Washing Machines
No spin cycle
dear zoofan.lets see hum.....to agaitate the motor goes one direction.to spin useing the same belt it goes the oposing direction.so when spins lid switch completes curcit to motor then it would spin so if click you hear is the motor protector switch [its like a curcit breaker] kicksout that means you lid switch is working. but could the noise be the timer advancing? timer makes clicking noieses also.then that would put into question your lid switch.but you said it starts again after a few minutes.if thats a sure thing then it ,your motor is involved but a possiable is somthing is between the tubs[thats a visiual inspection]sock,any clothing or if had a nail or somthing of that sort going thru small holes in inner tub then jaming or draging on the outer tub that could stop the tub but most of the time the motor would go and would burn the belt.hope i gave you a few clues,God bless ,tom
Jan 06, 2009 | Frigidaire FWS445RF
Frigidaire FAFW3801LW Washer Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
