Question about Ford 8N Tractor
Why does my 8N Ford tractor die at about half throttle?
Full tune up, rebuilt carb, if I pull power needle it will rev all the way. new fuel shut off valve and cleaned tank. was running ok then started this
  • 1 more comment
  • Matt Southard
    Matt Southard Mar 30, 2014
    it starts and runs great to a little least than half throttle will run all day that way checked timing all good new everthing and it does not have fuel pump thanks
  • Matt Southard
    Matt Southard Apr 01, 2014
    i have pulled carb 4 time. installed inline fuel filter no defferace if i pull power/main needle adjustment rev up not sure of power have not drove it that way
  • tractorman44
    tractorman44 Apr 14, 2015
    I'd bet the nozzle above the main jet is partially plugged. That;s the long brass tube that sticks up at an angle through the venturi of the carb. It'll have a hole all the way through and possibly as many as six opposing holes up the length. It is removed with either a 5/16 or a 3/8 deep socket to expose the main jet underneath. Once removed, thoroughly clean all holes and clean the main jet also. That should make a big difference.
  • 4 Answers
Sounds like it might be starved for either air or fuel. Have you made sure there is full gas flow from the tank to the carb? Also recheck the needle valve regulating gas flow into the carb. May be that a speck of trash is partially plugging that flow to carb. Should have in-line fuel filter (add on) in addition to the bowl 'filter
Posted on Mar 31, 2014
protek480
  • 1723 Answers
SOURCE: Ford 8N will not start when hot
This sounds like a bad fuel pump to me. The only way to be sure is to check the fuel pressure when cold, probably around 45 PSI. Then when it get hot it will drop way down to 10 or 15 PSI. Check the pressure if you can, or change the fuel pump.
Posted on Aug 14, 2009
  • 8 Answers
SOURCE: ford 8n sometimes just stops-very hard to restat.
Could be a bad condensor or coil, flaking out when they get hot. If it starts ok after it cools down about an hour and is cold, then very likely the problem.
www.Ford8n.com would have everything you need for replacements.
Posted on Dec 22, 2009
  • 8 Answers
SOURCE: 8n ford backfiring through carb
Engine is either out of time, or plug wires are crossed to wrong plug.
Firing order should be 1, 2, 4, 3
If you need new plug wires or timing gears, try www.Ford8n.com
  • 165 Answers
SOURCE: I have an 8n ford tractor,I have good blue spark
Choke working OK? Try a scooch of starting ether in the breather----not too much or might blow the head gasket.
Posted on Feb 27, 2010
  • 31 Answers
SOURCE: my 8n ford wont start with new carb, points,
I have also changed my plugs, points, cleaned carb, but I can not get the tractor to fire at the cylinders. I have spark but will not crank. What do I need to do?
Posted on Jun 26, 2010
Craftsman Leaf Blower will only rev up about 1/2 power at full throttle. Any suggestions?
If this is a two cycle engine there are adjustment screws that set the fuel mixture when the throttle is depressed.
Dec 02, 2016 | Craftsman Garden
Troubleshooting
Carb needs to be rebuilt, new needle and seat also float fuel level is critical.
after uninstalling carb remove fuel bowl turn carb upside down to verify float is parralell (level) with carb body if not adjust tab on float so it is clean all small orfaceses and jets.
Aug 09, 2014 | Cub Cadet Garden
I Have a Ryobi Trimmer. I cleaned out the carb and put it back together but forgot the High and Low needle settings. I have got it to start but am having trouble tuning it. I have put a carb kit in it and...
adjust the needles both all the way in until they stops. unscrew both 1 1/2 turns and start engine. slowly accelerate and if it bogs down unscrew the HIGH SLOWLY until full speed is gain. some times you have to unscrew a little the low speed too. is a matter of playing with it. be patient you will get it. if you are still having problems you may have to take the bottom of carb. out and make sure the gas inlet needle is letting pass gas into the carb. chamber.
Feb 16, 2011 | Ryobi Garden
the high speed check valve is most likely stuck and not allowing fuel to flow properly. the bad thing is it cant really be fixed. i have had some luck removing everything and putting it in an ultra sonic cleaner for about 10 minutes. however the fix doesnt usually last long. may want to look in to a new carb.
Feb 16, 2011 | Garden
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
41 9n ford motor not powering up enough
This one sounds like it may still be out of time.
Aug 27, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
My 9N is having trouble starting. It turns over fine but seems to be flooding. When it finally sputters to a start, it takes a while to run smooth. Also the idle seems to be fast and there is no change in...
Shut off fuel to carburetor, drain carburetor. Open fuel and count to three then shut off fuel. Crank engine then pull choke for 1 second then push in. If engine starts open fuel valve at tank. Also try lowering float level in carburetor. Good luck.
Jun 26, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
8n tractor runs good at first then after awhile starts to sputte
Check fuel filter in the shut off bowl. Then check the needle and seat in the fuel sediment bowl on the bottom of the carb.Also check the float when you pull off the sediment bowl.
Apr 15, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8N Tractor Logo
769 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
Rob Woolcock
Rob Woolcock
George Christ
Are you a Ford Toy Expert? Answer questions, earn points and help others
