Question about LG DLE2240W Dryer
Lg DLE2240 dryer is not drying
Not drying properly
Does not heat and dry the clothes
Most of the case, no heat caused by safety thermostat open. Replace new one if possible. It located at side of the element cover. The one with a pop up button.
Sep 02, 2013 | LG DLE2240W Electric Dryer, 7.3 cu ft...
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
DRYER ISN'T DRYING PROPERLY. TAKES MULTIPLE CYCLES TO DRY
Long dry times are usually always caused by poor air flow. Check the venting all the way from back of dryer all the way to where it goes outdoors,also for lint build up in tube where vent connects to on back of the dryer
Aug 12, 2011 | LG DLE2514 Electric Dryer
Lg gas dryer has heat and is venting properly but clothes take 2-3 cycles to dry compared to before single cycles.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 05, 2011 | LG DLG6952 Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Lg dryer does not dry clothe properly
the drying and cooling light is on and will not dry properly.
Sep 17, 2009 | LG DLE2514 Electric Dryer
LG DL2610 model does not dry, it turns on properly
Check your vent. Make sure there is a strong flow of air out the outside vent cap. If not, your dryer is not able to get rid of the moisture. Check for lint build up inside vent piping and for crushed flex vent pipe behind dryer which would obstruct air flow.
Sep 16, 2009 | Dryers
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Dryer LG 6DTD3120
You should change it back to regular gas the problem is in pressure reg gas come to your home at much greater pressure then propane that's why it takes longer to dry the other thing is to keep your lint trap clean because it can affect drying once in while blow out lint hose as well
Jul 26, 2008 | Dryers
LG DLE2240W Dryer Logo
32 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
