Question about Cadillac 2008 Escalade Ultra Luxury EXT AWD
08 Escalade temperature gauge moves towards hot while idle
While sitting in traffic temp gauge moves towards hot, then when driving it goes back to normal
3 Suggested Answers
  • 1348 Answers
SOURCE: 2004 Cadillac Escalade Engine Stalling when idling in hot weather
electronics supply place sell a spray that cools to -60f.
there is a component or device overheating,and if you spray freeze spray on the suspected items,the stalling will go away until it heats up again.
Posted on May 26, 2009
homeboi19
SOURCE: runs towards hot side when
i have the same problem with my 95 eldorado and i dont know how to fix it i done changed out mt thermostat and still it overheats
Posted on Feb 26, 2013
1996 jeep cherokee temp gauge reads hot 10 mins. after start-up
If you have a viscous fan hub then have it replaced as it is not drawing air through the radiator at idle or slow speed (crawling traffic). Check that are no air locks in the system as they will cause heating problems.
Jan 09, 2014 | Cars & Trucks
1990 dodge dakota 2.5 over heats temp gauge erratic
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----
temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge keeps fluctuating up and down close to red? http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Temperature gauge does not move and no heat when heater is ON? http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
This details will help.Thanks.
Feb 07, 2012 | 1990 Dodge Dakota
My engine temp gauge goes way up when the car is stuck in traffic, when I begin to roll the temperature gauge goes back down. I assume that this is a sensor issue, can this be changed easily?
I would assume that the sensor is probably doing EXACTLY what it is designed to do....measure engine temperature! An engine will get hot when sitting in traffic if the radiator cooling fans are not working. The engine temperature will then go back down when the vehicle starts moving and air begins to flow through the radiator.
Get your radiator cooling fans checked!
Please also review this article: What Else Could Be Wrong?
May 09, 2011 | 2000 Hyundai Elantra
Describe your 2002 Astro van temperature gauge Problem. Gauge goes to redline quickly when idling for a few minutes; "Check Gauge" light comes on. When van turned off, OK within 3 minutes or less. Temp...
Check coolant level, and possibly replace thermostat. When a thermostat gets stuck in the closed position, coolant does not circulate thru motor. Gauge stays midrange when driving, because motor is being cooled by air and or the fan. If car seems to operate completely normal, then the gauge is faulty.
Apr 01, 2010 | 2002 Chevrolet Astro
Fluctuating hot water gauge for Subaru Baja
check your coolant level, its may be low causing the fluctuatiion also the loss of heat. if its ok replace your thermostat its not regulating tempature right
Feb 27, 2010 | 2001 Subaru Forester
Given your high guage temps of 210 degrees and high ambient temperature of 100 degrees, your engine's stalling can very likely be linked to either one of these three causes: 1) vapor lock; 2) percolation; or 3) PCV malfunction. Here's a really good diagnostic article that precisely addresses this issue of yours:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Engine_System_Engine_Stalls_When_Hot.htm
Hope this helps! Brad
May 26, 2009 | 2004 Cadillac Escalade Esv
BMW 325i (2001) overheating?
Hi there, you are experiencing a water pump failure. this may be in conjunction with a faulty thermostat as well. i wouldn't drive this car until you replace the water pump and thermostat. it will only cause more internal damage. hope that helps and, thx for using fix ya:)
Feb 05, 2009 | 2001 BMW 325
Temperature gauge shows hot
head gasket does the overflow bootle have bubbles in it when idleing warm if does most likey rear head gasket.
Jan 04, 2009 | 1999 Pontiac Montana
Temp gauge goes to full hot while at Idle
Check the auxiliary cooling fan for operation. As the engine temp rises, it should kick on to bring the temp down. U may have a bad motor on the fan, or more likely a bad fan switch.
Dec 22, 2008 | 2001 Jeep Grand Cherokee
Cadillac 2008 Escalade Ultra Luxury EXT AWD Logo
15 people viewed this question
Top Cadillac GPS Experts
J.D. Browning
J.D. Browning
syspro
Todd Arndt
Todd Arndt
Are you a Cadillac GPS Expert? Answer questions, earn points and help others
