Question about Electrosport 1993-1998 Kawasaki Klf300 Bayou 4x4 Atv Plug-in Electric Regulator
Klf 300 4x4 new carb but spit and sputter mid throttle but runs good full throttle then just turn off like you turned the key off dont have a clue put new plug in and new gas tank
New carb and new gas tank new plug and gas still not running right
Why won't my bike run when I turn the throttle
Sounds to me like a broken throttle cable try that.
Jun 22, 2014 | Pitney Bowes 9920 Plain Paper Fax
Runs slow
In California the new blowers have sealed mixture adjustments and you need the have your carb. mixture adjusted be a qualified shop. If your carb. HAS mixture adj., turn the high speed mixture so it runs best at high speed, then turn another 1/8 turn counter clockwise to be a little rich. Then at idle adj. the other screw till it idles best.
Apr 21, 2014 | kawasaki Krb300a Backpack Leaf Blower
Rider...stalls after running a few min.. plug
maybe need to put a full kit through carb. and replace few worn parts ie. float needle and seat. throttle needle and seat etc
Sep 06, 2013 | Garden
Hs45 backfires spits
Sounds like an over fueling issue, Try resetting the carb to its standard settings, screw both tuning screws right in ant then turn anticlockwise to the following settings H 3/4 of a turn. L 1 full turn. This should set it back to standard. If this doesn't help then it could be a carb diaphram or sticking needle.
Jul 15, 2013 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
I put a cometic headgasket on upside down in my sons 2005 cr85r
the rejeting of the bike is most likly the cause of the sputtering. Maybe the size of the jet doesnt suit the altitude check to see that the jet is not too big.
Sep 18, 2012 | Honda Motorcycles
91 fzr 600, it will spit and sputter and barely go, and then it will clear out and take off like a rocket, and then it will start sputtering again. over and over
sounds like fuel delivery, check ur fuel pump first....grab a cup pull the hose that connects to the carb and the tank should be (red) turn the bike on dont start just turn the key on, it should pump fuel(a pretty good flow) if its pumping carbs are possibly dirty, if its not replace it, is ur battery fully charged, and all post secure?
Jan 23, 2011 | 1991 Yamaha FZR 600
I have a kawasaki 300 byou 1990 moled 4X4 that i put a carberator kit in but just doesn't run right spits and sputters when i give it gas it will idle ok sometimes. drained all gas and cleaned out good....
It sounds like it is running too rich (too much fuel). First, make sure the air filter is clean and that there are no intake leaks between the carburetor and the engine. Also, try a new spark plug (they can go bad without warning). Then, with the engine at normal operating temperature and idling, adjust the idle mixture screw to attain the highest idle speed. After this, set the idle to the correct speed using the idle speed adjustment screw.
Test ride. If it still spits and sputters at half to full throttle, then you will need to get a smaller main jet - or go to a less restrictive air filter, such as one by K&N.
Finally, I am not sure what prompted you to put a carburetor kit in, but if the bike had been sitting for any lenght of time (more than 6 months) make sure the carb isn't plugged up.
Nov 20, 2009 | 2003 kawasaki KLR 250
Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
Electrosport 1993-1998 Kawasaki Klf300 Bayou 4x4 Atv Plug-in Electric Regulator Logo
63 people viewed this question
Top Electrosport Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrosport Electrical Supply Expert? Answer questions, earn points and help others
