Question about Baby Lock Ellure
Wiper error on babylock enterprise
I got a "wiper error" message on my babylock enterprise. What does that mean and how do I fix it???!!!!!!
Babylock rachel.... when I turn my stitch dial to 2 I get an e8 error, what does that mean my machine is brand new?
If it's brand new, take it back where you purchased it. It should be covered under store policy or warranty.
The manual usually describes error codes in the troubleshooting section. Or, you can search online:
Make + Model + the words "error code E8"
Nov 09, 2016 | Sewing Machines
How to clean wiper sensor on enterprise
Cutter blade needs replacement. Sensor is likely fine and is not located in the bobbin case area.
Sensor is telling you there is a cutter error. More than likely need a new cutter. Easy enough.
Cheers,
Kelly
San Diego, CA
May 09, 2014 | Baby Lock Sewing Machines
Babylock emp6 power supply voltage low
Time to bring it in for service, maybe the transforme board.
Mar 01, 2014 | Brother Sewing Machines
Janome MemoryCraft 6500. What does error message "BM init error" mean? What does it take to fix it?
That's an initiation error. I would call Janome direct and ask them.
Dec 02, 2012 | Sewing Machines
How do I fix the error on a babylock emp6 "trimming sensor error?
I have found that this error most commonly is a result of a lot of thread caught in the cutting blades preventing the cutting blade from moving. See the "Cleaning around the Needle Plate" in the User Guide or "Cleaning of Knives and Rotary Hook" on page 316 (or 6-6) in the Service Manual located at http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf.
Oct 07, 2010 | Baby Lock Sewing Machines
Can the babylock Ellure be upgraded to USB?
You could do worse than ask a Babylock dealer or their general contact, both available HERE
Sep 10, 2009 | Baby Lock Ellure
My babylock says THE SAFETY DEVICE HAS BEEN ACTIVATED. The belt is not broke. I have changed the needle and pressure foot and still when you start to sew it does nothing and the above wording comes...
When you get that error message it usally means there is a jam in the machine that is causing the motor to work to hard so it keeps you from burning up the motor try taking your needle plate off and bobbin case out and then put your needle plate back on and then the bobbin case if that doesnt work try looking at the take-up lever there might be thread wraped around it soaking up the oil and causing a bind
Jul 02, 2009 | Sewing Machines
Balance wheel locked on crafter's choice
try this site and see if the download gives you a troubleshooting code.
http://www.babylock.com/downloads/instructions/?Update_ID=95
Babylock.com has really good cust. service, but your dealer should know what steps to take to clear this code.
If the sell an addtional information book on your machine, and stitching BUY it, it was so worth my $70 for my Evolve book (200+pages of HOW to's for that 8 thread monster!)
I hope this helped
Dec 23, 2008 | Baby Lock Ellure
Sewing Machines Logo
181 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
