Question about Lithonia Lighting Home
Setting time on lithonia msx12
Setting time
How to reset the msx12 light as it is not turning off
I got everything from microphones to motorbikes on this one.
What is the item and where?
May 14, 2017 | Cars & Trucks
How do you remove a lithonia floresecent light cover
It either spins off or it is spring loaded. Just pull down.
Nov 11, 2013 | Lithonia Lighting Fluorescent Flush Mount...
Lithonia photocell light stays on during the day
1) Buy twist-lock photo control:
http://www.intermatic.com/en/Products/Sensors/PhotoControls.aspx
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Dtools&field-keywords=twist+lock+photo+control
2) Spray bit of WD40 on twist-lock blades before installing new photo eye, and then rotate back and forth a bit to make sure there is electrical contact.
Test by placing black tape over photo eye.
Feb 14, 2013 | Hardware & Accessories
We have 48" lithonia flouresent
even if there is power at the sockets, ballast may not have power to fire off the lamps, how old is this fixture, and you need to replace the ballast same as in fixture, if you replace ballast make diagram of wiring so you can rewire it like it was wired from store.
Aug 21, 2011 | Lithonia Lighting White Finish 2 12" High...
The florescent ceiling light in my kitchen takes a long time to turn on after flipping the switch. It is a lithonia light model# 764123
Flourescent Lights use a 'starter' to build up a charge which then jolts them to life. It sounds like your starter is struggling to do the job. The starter is usually located on the side of the light casing and looks like a cylinder which partly protrudes from the case. It twists and comes out and is easily replaced.
Jul 17, 2010 | Lithonia Lighting Psq500 Power Sentry...
Kill power to light and emergency single light does not turn on also with power on push test knob and emergency bulb not come on
Hello Ramon, Check the power back (battery cell) as without a functioning battery pack, the emerbency light won't function.
Typically the batery packs will need to be replaced periodically every 4-5 years, depending on the istallation location and ambient temperatures.
When you kill the power to the emergency lighting circuit the PSQ is switched to operate automatically on battery power only. The same thing occurs when you press the test button; it disconnects the lighting from the electric power that keeps the battery charged and ready for service. You might also want to check the bulbs with a test meter (remove the bulbs from the fixture and test with the Ohm setting) While rare that these bulbs burn out, since they aren't usually illuminated often, only during a power disruption/outage, etc.
Here's a link to the Lithonia site with the spec sheets for the PSQ series of emergency lighting products, for your use and reference.
http://www.lithonia.com/product/advSrch.aspx
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | Lithonia Lighting Psq500 Power Sentry...
Changing ballast
Here is the link for wiring Lithonia Power Sentry Ballasts: http://www.acuitybrandslighting.com/Library/LL/documents/Installation%20Instruction%20Sheets/PS.pdf
Hope this helps Sparkylikes480
Mar 27, 2009 | Lithonia Lighting Psq500 Power Sentry...
Home Logo
281 people viewed this question
Top Lithonia Lighting Home Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gene Haynes
Are you a Lithonia Lighting Home Expert? Answer questions, earn points and help others
