Question about Maytag EPICz 3.7 Cu. Ft.
Pump not working
Pump is not pumping out the water
My water supply pump to house works but does not pump water from tank to house
What type of pump is it? Is it a shallow well pump or submersible
pump? Is the pump connected to a pressure tank? How have you confirmed that the pump is working properly? Is there a drain valve, and is there water pressure from the drain valve when it is opened? If the pressure tank is of the pre-charged type, is it working properly? Is there water coming out of the air valve? Are there any shut-off valves in the system which may have been turned off, preventing water flow?
Apr 17, 2014 | Saniflo 021 Saniswift Residential Water...
How do i replace the water pump....3.3 L
first find the water pump for every vehicle ive ever worked on the water pump is always right above the main pulley once you locate the pump unscrew the hose from the pump to the radiator and then take all the bolts off the pump slowly wiggle the pump off so you don't damage the gasket on the water pump then take your new water pump and line it up to the holes for the bolt and put all the bolts back in and then reattach the water pump hose to the pump and to the radiator and then fill the radiator up and your good to go
May 07, 2012 | 1991 Dodge Dynasty
How can you tell if your water pump is even working
Water pumps FYI
A belt drives your water pump, most are the same belts that turn your altenator and air compressor. Some water pumps are turned by the timing belt. But if you can see that your belt is working the water pump, altenator and compressor, its working. If you had a water pump powered by a timing belt, you would not be able to start your car if that belt stoped.
Water pumps never stop working, they are direct shaft driven.
The only thing is they do start to leak after they get older, then need replacing.
Apr 15, 2011 | Kia Sportage Cars & Trucks
Replacing the water pump on 96 chevy S10,
Water Pump Removal & Installation 2.2L Engine To Remove:
  1. Drain the cooling system.
  2. Remove fan assembly.
  3. Loosen the water pump pulley bolts.
  4. Remove or disconnect the following:
    • Water pump drive pulley bolts
    • Radiator inlet hose clamp and hose from the water pump
    • Water pump
    • Water pump gasket
To Install:
  1. Clean the mating surfaces.
  2. Install or connect the following:
    • Water pump gasket
    • Water pump Note: Apply a sealer (GM P/N 12346004) or equivalent to the bolt threads
    • Water pump mounting bolts
      1. Torque to: 18 ft lbs (25 Nm)
    • Water pump pulley and bolts
    • Radiator hose and clamp
  3. Fill with coolant.
  4. Check for leaks.
4.3L Engine To Remove:
    • Water pump
    • Water pump gasket
To Install:
    • Water pump gasket
      1. Torque to: 30 ft lbs (41 Nm)
  4. Check for leaks.
Feb 12, 2011 | 1997 Chevrolet S-10 Pickup
No water from drilled well, intermittent.
1-If everything has been replaced can you turn water off and check air pressure in the water storage tank. the bladder may be leaking and causing it to work some. A 40 gal tank should have about 28 psi of air in it. Also you can press on valve at top of tank to see if any water comes out will let you know if it's bad. Air should come out at top and no sign of water from valve on tank..
2-When you changed pumps did you replace the check valve in top of pump. Some pumps I have had to pull back up and add a check valve to pump.
Most pumps have a check valve on top with a retaining clip holding it in. And they work sometimes and some have to be removed and add a brass check to pump and connect to water pipe.
May 19, 2010 | Plumbing
Need to now location of the water pump
Check the thermostat first. Follow top water hose from the radiator to the water pump. To check for problem with water pump see if you see anti-freeze somewhere leaking or do you hear a strange noise. Also check your top and bottom hoses.
May 28, 2009 | 1997 Cadillac Eldorado
Sump pump not pumping water properly
If your pump is turning then something is stopping the water from being removed. If you can see the pump check to see if the water is becoming turbulent when the pump kicks on? If the water doesn't appear to move or is moving only a little then either the pump impeller is damaged or the screen that keeps debris from entering the pump is clogged.
If it's never been cleaned it is most likely just a clogged filter screen. Clean it and it should work fine. If however the screen is clear then it is either a blocked line or a bad pump. And yes a pump can still run and not pump, if the impeller is bad.
May 19, 2009 | General Plumbing
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Stiebel Mini 4 won?t activate using 40l/min pump
You have to make sure that the pump is flowing enough water to activate the Stiebel. The tankless unit has a activation rate of a certain amount of water to turn it on.
Jan 18, 2009 | Stiebel Eltron Mini-4 Tankless Water...
Pump works but is not pumping water
IT SOUNDS AS IF THE PUMP IS NOT PRIMED. MAKE SURE THE THE PUMP IS FUL OF WATER
Jan 11, 2009 | Flotec Corrosion Resistant Shallow Well...
Maytag EPICz 3.7 Cu. Ft. Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
